Need new tires ....comment?
I need to replace a set of All Season tires. Currently I am using Falken ZE 512 A/S but not very happy to it because of durability. This set of tires only lasts approx. 35000KM.
Rims are 02-03 17" TL Type-S 17X6.5
My choices currently are...
1) 215/50 WR17 Bridgestone RE960 A/S
2) 225/45 ZR17 Michelin Pilot Sport Plus A/S
3) 215/50 VR17 Toyo Versado LX A/S
Which tire should I get according to ride quality, handling, winter traction and durability?
Thanks all
Thanks all
I have the 960's on my other car and have about 10K miles on them with no sign of wear. They were the #1 rated ultra high performance tire at the tirerack. My only beef with them is they tend to flat spot but that may be due to the car sitting more then being driven.
AZ Member.. :X
Inspire,
Out of the choices you listed, the RE960 would be the best based upon current available data for wet & dry. The Pilot Sport A/S Plus has not been tested,* but it is the same tread design as the original Sport A/S which was superior to the RE960 in the snow, particularly in straight-line traction as well as cornering. So, when it comes down to the RE960 or the Sport A/S Plus, just ask yourself how important is the snow capabilities of the tire and base your decision accordingly.
The Versado LX is a touring tire and simply not in the same league as the Pilot Sport A/S Plus or RE960.
* = The newer compound of the Pilot Sport A/S Plus may make it more competitive with the RE960 in the wet, however, we simply do not know if this will be the case.
Inspire,
In your knowledge....if the snow capabilities of the tire are important to me as well as wet and dry road conditions, RE960 or Pilot Sport Plus would be the best pick for me?
Thanks.
Sippy Cup (x2)
I used to have the Yoko AVS ES1000 or something like that, and your friends are right. Of course, if your not lowered it probably wouldn't be as bad. They do have pretty crappy tire wear though. I just recently put Nitto Neo Gens on my car (about a year ago actually) and I love them. They are non directional so you can rotate them properly (X pattern) and they are all season high performance tires. The grip in dry weather is amazing, as well as in rain. We don't get much snow so I can't say anything about that. I would highly recommend them though. They were the second highest rated tire according to consumer reports and the people that I know that have them love them...myself included. I'll probably get another set when it's time to replace these.
Michelin touts better dry & wet handling than the RE960 and F1 A/S with their new Plus tire, but curiously, they do not provide any data from their supposed "independent test." Thus, I still believe the RE960 will be better in the dry, and probably better in the wet. I don't appreciate companies that make a boast about their product based upon alleged independent tests, yet refuse to reveal the details of such tests.
I had the PS A/S and got about 50k out of them. They were very good in dry and wet and handled snow really well for a HP A/S.
The Goodyear F1 A/S seems to be a good tire as well.
Thanks all....
so my question is ... which one should I get? Bridgestone RE960 a/s or Michelin Pilot Sport Plus a/s?
which one will last longer?
Michelin P/S doesn't have the size of 215/50 R17 but 225/45R17.
Will there be a problem for stock 17" TL rims? since stock rims are 6.5
Michelin PS Plus A/S in 225/45/17 is not recommended on a 6.5" rim width. Some installers won't install them due to legal reasons. Recommended rim width range: 7.0-8.5")
Instead ... you can use 205/50/17 ... but your dry performance will suffer due to smaller contact patch with the road (but will improve on winter / light snow performance -- re: greater traction).
Edit -- nevermind ... load rating for the 205/50/17 is 89 ... it is recommended that you'll need 93XL if you drive the Type-S. (And our cars are very nose heavy ...) You might be better off with 225/50/17 but you run across the rim width dilemma ...
Actually, derrick, the approved wheel width for the 225/50 R17 is 6.0" - 8.0", go figure. If he wants the Pilot Sport A/S, 225/50 R17 will be the one to get. A little bit taller, but hey, it will fill the wheel well better
2006 NBP TL MT6/ 02TL-S
New all-season tires....
After researching Tire Rack and other sources, I am about to order a set of the new Goodyear Eagle GT UHP All-Season tires.
They are mid-level priced tire if you get them from Tire Rack. I think they may be the new hotness in UHP all-season tires.
and throw off your speedo and have a squishier ride and handling. Id stay as close to stock as possible.
Sippy Cup (x2)
I wouldn't go with a larger sidewall. The ride may be a little better but cornering will be a lot worse. I have 225/45 17 on my car and the speedo is off by about 2-3 mph, of course that is with the Neo Gen, not the PS A/S.
We're also talking a total wheel diameter of 0.4" larger. This too really isn't that big a deal. If he wants the better snow performance of the Pilot Sport A/S Plus AND keep his OE wheels, 225/50R17 is his only choice for that tire. I'm not suggesting he do that, only that it can be done. I'd be more concerned though, with throwing off the ABS.
The RE960 is a great tire, and comes in 215/50 R17. That would be my recommendation for this application.
Certainly for wet & dry. In fact, there might not be a better wet- UHP A/S tire. Snow traction will be questionable, and noise is an issue compared to the quietest UHP A/S.
DO NOT the original poster's thread. Use the PM (private message) or better yet ... post your sale of the tires in the off-topic > black market like everyone else does ...
CostcoFanAUS
09-18-2015 06:05 AM
