need help on some rims....
will this fit our 2g tl's?
Size: 18x9 all around
....im new here ive done my research ive seen some crazy staggerd set ups but havent seen any setup like this can it be done? I already know I would need to cut tabs roll the fenders and also get a camber kit but thats no problem
thanks guys
Bolt Pattern: 5X114.3
Offset: 50
Centerbore: 73
Offset: 50
Centerbore: 73
thanks guys
thanks jjashaa i feel a little more confident with my soon to be setup. one more question where can i find 10mm spacers that are a pretty good deal price wise?
if you are going for 10mm spacers, mind as well get 15 of 20mm because you are going to use extended lugs anyways, so make the most of your money and push it out more. itll still work, but youll need to stretch atleast a 225/40 on your wheels.
but if i go that much itll be harder to clear the front at a nice flush look with out putting so much neg. on the camber right? or its worth getting the 15mm or 20mm?
murph145
02-18-2012 07:00 PM
