Lowered drivers, tire wear question
Is it a given that lowering your car WILL wear the front-inner part of the tires quicker? Seems like I have to buy new tires every year, regardless of proper rotating and alignments.
I keep seeing 40,000 mile warranties, 25,000 mile warranties, etc. but my tires NEVER last that long.
Is it just a combination of suspension mods (sway bars, polyurethane radius rod bushings, etc.) + lowering springs? Kind of a "comes with the territory" type thing?
justnspace (06-06-2012)
TLtrigirl (06-06-2012)
EDIT: I also only have a rear sway bar, not a front one.
deal with it
wearing even like each tire wears out even across? the inside and outside have the same as wear...theres not one side of each tire wearing out before the other side?
you can get a slime thread wear gauge for like $2-3 at advanced auto parts and auto zone, then check the outside of the tire, middle, and inside, if they have worn evenly then its a combo of the roads and how you drive
I'm wondering if it's my lower control arms, after doing some research.
OR, just do the camber kits and call it a day.
However, I believe the addition of a front sway bar would not disappoint.
Good luck.
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
