Ksports Custom Spring Rates
should i spend more in
I have an 03 TL-S and I'm currently on Eibach Pro-Kits and blown shocks, so my ride has turned to crap. I just bought some 19's, so I know its not going to get any better so I'm looking for a new suspension setup. I was initially considering Koni Yellows, but for the prices I'm seeing, I figured I may as well save up another 100 bucks or so and get Ksports. I know a lot of reviews have said that they are stiff, with the 13/7 spring rates, and I definitely want to keep the feel of the Eibachs which is sporty but not stiff and bouncy. I called up a shop in Arizona and they can get the Ksports for 780 and I can do custom spring rates for no extra charge. I believe the Teins are 7/4. Is that correct? Is it just the rear spring rate that I should really be concerned with? Am I thinking about this the right way? Just want to make sure.
AZ Community Team
Received 7,771 Likes
Here's the spec on Tein's. Not familiar with your spring rate notation (noob), so maybe this isn't what you're looking for.
http://www.tein.com/products/s_tech_price_list.html S-Tech
http://www.tein.com/products/high_tech_price_list.html - H-Tech
http://www.tein.com/products/super_s...rice_list.html - Super Street Coil Overs
6G TLX-S
What do all these 7/4, 10/7, 9/7 mean ?
AZ Community Team
Originally Posted by c0v3rr1d3
they are spring rates front/rear higher = stiffer/harder ride.
Lamborghini Aventador FTW
Originally Posted by Bearcat94
What does a "spring rate" of 7/4 mean? 7 of what and 4 of what?
AZ Community Team
Originally Posted by AMGala
Basic physics, spring rate is the amount of weight needed to compress the spring. This is usually measured in grams/mm (metric) or lbs/in (US). In the case of these car springs, the 7 and 4 are measurements of the spring rate in kg/mm, so a spring rate of 7 kg/mm means it takes 7 kg of weight on the spring to make it compress one mm.
7kg compresses the spring 1 mm.
But, what's the 4?
Is 7 the front spring rate and 4 the rear?
That's Racist
i had the 7/4 teins, then the 13/7 k-sports; gotta tell you, 13/7 is VERY aggresive; but really fun in the corners =p.
literally no body travel and no rubbing when i had a less than half finger gap from tire to fender lol
Dont even worry about spring rates. You can achieve a better more controllable ride with better adjustable shocks, and just stick with what the manufacturer has made the spring as. H&R wont tell you because most people dont know how to comprehend the #s properly.
https://acurazine.com/forums/showthr...t=spring+rates
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
