info on camber kits
info on camber kits
well i bought a set of F/R used spc camber kits, basically the rubber boots are torn, and yes the grease can come out, when i installed my coilovers, the mech. said dont install em, cuz its fairly damaged, they will squeek...and all the grease will run out....is it true? i loooked on some pages about ingals and they dont have a boot over it....so i duno who to believe, i woul dlike to avoid camber, for now i dropped it a inch or so...ill post pics later wit the camer kits on how they look and the car....but basically the ? is, will it be ok if i install them?
Call your local Acura or Honda dealer and order front tie rod boots. Im guessing that they will fit or can be made to fit. The cost should not be very much and having them protected is always better then leaving them uncovered. I have the same rear camber kits and they give me zero trouble.
Get yourself new ones. The joints look to have been contaminated for some time. Save the headache and get new. You will have to either pay or do the labor all over again when these fail.
Id get some new ones No telling how long those boots were torn and driven on.
spoiler900
10-10-2015 06:48 PM
