Infinti fx35 wheels on TL
here comes the snow!
Can I make them fit, same lug pattern, but center bore is 2 mm bigger on the fx, found a good deal on the wheels with blizzaks so I'm trying to figure out if they will fit.
Ackniculous One
if they bolt pattern is the same and and bore is bigger than 64.1mm, sure it will work..but if you can't find hub rings to fill that gap, you will have vibration regardless of type of tires you have and how good they balance them..there are sites that have hub rings, discounttiredirect.com has hubrings that might work...also have to consider weight..i would expect those wheels to be heavier and also consider width and offset to make sure they fit and don't rub
JByron
01-08-2016 09:49 PM
