Hub Centerbore help!
Low & Slow w/Dubz On My
73.1 and get hub rings...NO WAY to the 56.1 waaaay to small man...
IMO, get 73. At least you can still test mount it to your car without the adapter. with 56, you can't. But, it is a good idea to look for the adapters first before purchasing the wheels.
i got my hub rings on Ebay for dirt cheap..i didnt have them on at first wit my 20's and there was some vibration/shaking but after i got them put on it felt smooth...
as long as you use the correct hubcentric centering rings you are fine
The wheel has to be the larger size
Get them Hunter Road Force balanced for best results with larger tires-rims
It can even tell you where to run each tire on the car !
Note- tire shops tend to forget to put the rings back on after a balance and rotate job
Always be sure the tech knows of the rings- (paint them a bright color) and watch them get put back on EACH rim- most click into place on the rim.
Also make sure the wheels are tightened BY HAND in 3 segments of torque
The rings need to sit flat on the hub and the wheel depends on them to be dead center on the hub
Even torque at the correct pressure of 80 foot lbs on the lugs, will save your rims and rotors-lug studs and more from expensive damage
jmoney2001
09-11-2015 12:07 PM
