G35 Wheels
318whp/289wtq @ 6psi
I don't know if I would put infiniti rims on an acura or acura rims on a infiniti but that is just me. They might fit but why not just buy some aftermarket wheels?
I think the G35 rims are +40 offset with 5x114.3J bolt pattern ... I don't think they would fit (provided they are 18x8 rims). If you can, do a test fit to see for sure. Personally, if you want something different, why not go aftermarket like suggested by the previous poster?
Ackniculous One
Offset and center bore size will be your concern. Our center bore is 64.1mm, which is smaller diameter than most aftermarket wheels that require hub centric rings. If G35 wheels have a bigger bore size, you may run into hub centric issues and vibration since the wheels are not snug on the hub. If the offset is under 45mm, you will have some possible rubbing issues also.
In 702, 808 in Dreams
i actually seen a guy here in vegas put the 7 or 8 spoke G35 wheels on his TL. the offset is too low. the wheel sticks out. Even the front does too. he had some nice wheels before and he switched to thoughs. in my sense it does not match. dont waste your time its going to look really funny. i think he ran thoughs wheels for a little while and i seen a different set now. It primarly due to the offset. it fits though just the wheel lip sticks out of our fenders. i wouldnt suggest it. maybe if the wheels had a slightly higher offset then it might look decent. but yeah id stay away from them.
JByron
01-08-2016 09:49 PM
