Front and Rear Sway Bar Bushings
Today when I changed my shocks, I noticed that my Sway Bar bushings are well worn.
I can't find my micrometer, does anyone know the diameter of the front and rear stock sway bar so I can buy the correct bushings for the sway bars?
2002 TL-S
2002 TL-S
Ok, since I cant find my micrometer caliper I used one of my childs very inacurate caliper to get a ball park. it seems to be about .5 mm off but using that variance it seems that the front sway bar is 27.2 mm. It seems that the rear is 22mm? The existing bushings are a red color.. is this the factory bar?
That sounds like you have a Eibach sway bar kit. If i remember correctly the front should be 27 and rear should be 22
^ i misread, thought he had red bars as well. If the swaybars are black and just the bushings are red odds are you just have aftermarket bushings on the stock bars.
09-04-2015 08:03 AM
