-- FAQ: wheel rim size "will they fit?" --
#161
Originally Posted by fsttyms1
Or maybe your rims arent actually a +38. Because the way they fit in the wheel well they dont look like it, they look closer to a +42 or more. Maybe the manufacturer has them labeled wrong or went about measuring them from a different location.
And your suggestion to do some research, Well thats what this forum is for. And the INFO posted is from Real life experience with people who HAVE tried different offsets. I tried a friends +38 (granted it was a 8") and stuck out outside the fender. 95% who use +42 rub or have issues. Id suggest any one who's doing research not to try a +38
#162
i want too buy those wheel does it fit un my 3.2TL 2001 ? tenzo-R GT5
18 "
5 X 114.3
offset : 48
they are wrapped in essenza type-R rubbers 225/40/18
here the link : http://img145.imageshack.us/img145/6721/img0141so1.jpg
18 "
5 X 114.3
offset : 48
#163
slobalt defender
18 "
5 X 114.3
offset : 48
18 "
5 X 114.3
offset : 48
they will fit almost perfectly, and your gonna want a drop when you put them on, your wheel well gap will look huge.
#164
Originally Posted by RidinDurty
Whatever you say buddy. I highly doubt the manufacturer made a mistake on the offset. Thats kinda rare if you ask me. Anyways, i have tried different offsets (not just on my car) and i think im a "Real" person too. Have you ever thought that maybe, just maybe your not always right on every discussion on this forum?
Whatever. You have what you have thats fine.
#165
18 "
5 X 114.3
offset : 48
18 "
5 X 114.3
offset : 48
#167
運転することを愛
Yes that is correct. With the tire being smaller than stock, it will make the speedo show that your going faster than you are.
If you are going 70 mph with my wheels (19x8, 35 profile) the speedometer will need to read 70.28mph to actually be going 70 mph (according to this calculater, there is actually a loss in total diameter since the profile is so small).
If my profile was the same as my stock type-s wheels, 55 (still on the 19x8s), then I would need to have the speedo read 62.19mph to actually be going 70mph.
So it appears as if with my setup there is really no change in the speedo reading. The calculator I was playing around with is claiming sidewall (termed as aspect ratio) has a big deal to do with things...
http://www.daviesautocare.com/tireinfo4calc.html
#169
I'm a big fat hippo
I'm a moron, please help with rim question
Great forum you have here. I just purchased a 2003 TL. I know absolutely nothing about tires. Will the rims listed below fit my car? Also, will the tires listed below look ok on my car? Any input will be appreciated. Thanks.
Wheel Size/Offset 17x8 plus 45mm
Finish Chrome
Condition Excellent
Center Caps included
Lug Nuts not included
Tires Michelin Pilot HX MXM4
Tire Size 235/45/WR17
Tread left 99.5%
Finish Chrome
Condition Excellent
Tread left 99.5%
#172
18x7 with +40 ... should be OK if you don't lower it and/or you pick 225/40/18 tires. Worse comes to worse ... cut the tabs in the back and if you still rub, roll the fenders.
Sadly, measurements are not an exact science ...
#173
運転することを愛
Unfortunately this applies to the actual manufacturer of the wheels as well...
#177
Originally Posted by datzdaboi
what offset would be recommended for 19x8 rims to clear a big brake kit ?
#178
Ackniculous One
All depends on the rim. a 19x8 with 45 offset may have less clearance than a 42 from a different type of rim. Hard to say. I have 45 offset 19x8 Zenetti Fives and I have a good amount of clearance, but not sure for a big brake though I just got some brembo OEM blanks and EBC green stuff and I'm callin it a day..
#179
This Is Scary!!!
This thread is awesome, but at the same time it got scary the more I read about this. I am scared to even buy wheels now with all this talk. The things that worries me, is difference in speedometer and odometer. I had that problem in my previous car when I bought wheels without any research.
I gave that car to my dad now that I am driving TL. But he didnt want to believe me that my tires were rubbing on the fender. But now, will all the info I got from here. I am sure I was right!!!!
#180
TSX Wheels
Im thinkingof buying some 17 stock TSX wheels, I think they are off an 04-05. I just wanna know if they will fit on a 99 TL that isnt lowered? I also need to know if they have the stock size tires that the TSX came with if they would fit, they are 215/50/17
thanks in advance
thanks in advance
#181
^ yes. they will fit
#182
Ok, I have read every single post in this thread about wheels and offsets. But I haven't came across anyone mention spacers. If the wheels you want have low offset, why not get some spacers? For Example: I want wheels XXXXXXX but offset is 38+, why not just get 20mm spacers to make it 58+???
#184
#185
Rubbing issues
I purchased a set of TSX 04-05 wheels 215/50/17 +45 offset I believe. I am at stock height right now and wonder if I got some H&R sports (1" F, .75" R) and some tokicos would I have rubbing issues?
I don't exactly know what the "cutting tabs" truely means, but if it means cutting into the fender liner, I don't think that would be wise for me here in WI since it would literally rust my car from the inside out. I am looking at a way to lower my ride w/o too much modification.
I know this is a "will they fit thread" but I think this should be ok to post here
#186
Ackniculous One
#187
Ackniculous One
UPDATE
Well, I gave in to the warm weather and put my 19x8 Zenetti Five's back on. (45 offset w/ 235/35/19 Falken Azenis tires)
I got out my trusty Dremel and trimmed my bumper tabs off. Put the wheels on and then drove around and no rubbing anymore!! At least so far anyway. To see if they would rub, I basically put my car at an angle at the end of my driveway to really "contort" the rear suspension since I have a pretty good size smoothed curb. By doing this, I am basically shifting the car weight to one rear corner and the opposite front corner and I have about 1/4" between the tire and the metal fender edge on the rear fender. Another way to do it is to turn the card hard on a turn to hear for rubbing, did that too and still good to go!
I know before, that tab would of been all up in my tire at that angle. So, with using my dremel, I trimmed the tabs in about 10 min for both sides combined. So all is good now, thank God!! I'll see about getting some pics up to show you all the clearance by doing this .
UPDATE
#188
2000 Acura TL
Originally Posted by CJITTY
UPDATE
UPDATE
Sounds good man, i think that the Acura God's listened to your beggin earlier. The last week or so has been absolutely beautiful, hope it stays that way....oh and def put up some pics
#189
Ackniculous One
Of course, it's FKN snowing today!! Oh well, shouldn't be too much accumulation. I had to cut more of my bumper tabs back last night and I think I got rid of at least 95% of the rubbing. I may need to go back another 2 inches or so to completely eliminate it, but all is good at least for now. Luckily, I got about 1/4 inch of clearance on the metal portion of the fender, so I don't think a fender roll will be needed. I contorted the suspension on a hard angle to where the wheel was tucking into the fender and I could barely get my pinky in the gap (sounds nasty) but not what you all might think LOL! I did the same on the other side to make sure it was even, it was!
Plus, I bought those metal hub centric rings from Discount Tire and replaced my plastic ones. I have no vibration now other than road feedback!!!! Yes Surrr!
#191
Originally Posted by dro_15
what tabs are your guys cutting?
https://acurazine.com/forums/showthr...highlight=tabs
#195
2007 NBP TL
most of the searches i have done have been based on entering make and model on some of these website, and they give you recommendations. a lot of the results vary from zero offsets to negative offsets (deep dish)...its gets very confusing. with that being said, if i want 19" wheels and do not want to be cutting into my fender, what are my options...it appears that 19x8 is the best bet, but what is the range for offsets i am safe with
#196
#197
Originally Posted by wowwy1
Hey - I'm new...I put a ton of miles on my TL and need to go with a simple upgrade to wider tire...has anyone posted pics with 225 55 16's?
#199
Question for Ridindurty
If you want to keep a good camber/alignment and you want to stick with 19x8 , I would recommend an offset of +47 or higher. That would be your best bet to not need any body work. BUT it also has a lot to do with tires. Tire size will help you out there too. With 19x8 i think 225/40 or 235/35 would be ok. I am not too sure because i have 18x8 rims with 225/40 +38 offset. You should ask people who have 19 inch rims and see what set up they have along with how much of a drop they have. There are a lot of variables you need to consider besides the offset.
#200
Originally Posted by davzilla
would G-GAMES 77WV (wolf 2pc) 18X7.5 +50 work better with 225/40/18's or 235/40/18's on a 99 TL?
thanks
thanks
