-- FAQ: wheel rim size "will they fit?" --
All,
When purchasing rims for a car, there are several specifications to ensure a good 'fit' (ie no need to do any fender mods).
1) rim size
2) rim width
3) offset
4) bolt pattern
Rims range from 16" to 19" for our cars. Any smaller and they won't clear the OEM calipers. Any larger and you will have issues with 'rubbing'. I'm sure someone will say, "I got [XX] size to fit", but seriously -- look at their setup and most will not find that look very appealing.
Rim width and offset go hand-in-hand. Depending on your rim width, you have to watch the offset. The wider the rim, the higher the offset (so it doesn't rub up against the wheel well or plastic tabs of the fender when you hit a bump).
Our TL/TLS come with 6.5" rims with +55 offset, made my Enkei. General rule (but not always the case since there is some variation among manufacturers):
7" rim = +42 offset
7.5" rim = +45 offset
8" rim = +48 offset
> 8.5" rim ... forget it unless you wanna do some custom bodywork for it to fit.
This is only a guideline, not an end-all, be-all. Those who have done suspension work may have to find a higher offset than that posted to make sure their application will not have any problems.
Lastly, bolt pattern -- our cars have 5x114.3JJ bolt pattern. Luckily, many rim manufacturers make this bolt pattern but offset will be your limiting factor.
1) rim size
2) rim width
3) offset
4) bolt pattern
7" rim = +42 offset
8" rim = +48 offset
The following 12 users liked this post by derrick:
AMBLACKW4T3R (12-13-2011),
brooklyn07 (10-21-2012),
cib16waker (08-02-2016),
Deemz64 (10-24-2012),
Dual-Saber (05-02-2016),
and 7 others liked this post.
Thanks for the Sticky ....sums up a lot of info very efficiently which I am sure I will reference a few times until I purchase my setup.
A piece of info that I am still missing to solidify my choice of rim is weight.
I am wondering if you could know and could include in the sticky the weight of the stock TL and TLS rim (16" and 17")
Thx
Thx
I like the info, but I have double checked and maybe it is the manufacturer of my rim (HP Evo's) 18X8 +48 offset) but the rims DO NOT fit the car. They stick out too far and when there are people in the back they rub. I have an 03 type-S with 25K miles on it so I think my shocks are fine. I could be wrong but I would strongly advise people to test a set of rims in the size and offset you are looking for and see what they look like on the car before purchasing.
I really recommend based on my experience that you stick to 55+ offset and as close to stock width as possible, unless you like the MEXICAN TRUCK "Look". I will email anyone pictures that wants to see just pm me. And Again just to reiterate this is JUST an OPPINION from my own experience I’m results will vary.
Later!
Later!
I will email anyone pictures that wants to see just pm me. And Again just to reiterate this is JUST an OPPINION from my own experience I’m sure results will vary with others.
Later!
Later!
a +48 shouldnt stick out the offset has to be wrong
Originally Posted by demolition_x
well would 19x8 with 235's stick out too far with a 45 off set. or will i ned to cut the tabs. trying to get a picture what works with modification and no modification.e
Im a little confused
Can you explain to me the offset? I dont really understand what it is, I mean i get the width....7" or 7.5" or whatever but the offset just throws me off.
i will post all the rims i had on my 2 gen tl and what fitment for you guys for reference, the order is what i have used since i got the car and what kind of drop with my rear bumper tab trimmed
wheel model fitment tire brand kind of drop rub or not notes
volk III 18x8 +41 nitto 225/40/18 h&r springs yes tab trimed
euroline ls 19x8 +49 nitto 225/35/19 h&r springs no tab trimed
zauber gettin 18x7.5 +51 dunlop 225/40/18 tein ss 2" no tab trimed
mahdi caesar 19x8 +45 pirelli 215/35/19 tein ss 2.5" no fender rolled
oz superleggra 19x8 +40 dunlop 225/35/19 tein ss 3" yes fender rolled
euroline kh 19x8 +45 dunlop 225/35/19 tein ss 3" yes only with R pass.
weds wal 18x7.5 +38 dunlop 225/40/18 tein ss 3" yes only with R pass.
rays g-game 19x8 +48 falken 225/35/19 tein ss 3" no stretch look tire
euroline sl 19x8/9 +45 dunlop 225/35/19 tein ss 3" no stretch w.camber
at first i trimmed a small portion of my tab, but as i moved on with more aggressive fitment i trimmed more and bought a roller tool for the fender, tires play a factor too, i never used 235, i always used 225, the one time i used 215 i could get 45 to fit with no rubbing because of the skinny tire. the shape of the falken st115 is naturally stretch look it gives you more room to play with on the offset. my current setup is 19x8 and 19x9, but be ready to change tires often because i cambered my rim to tuck. hope this guide work for you guys to choose wheel.
I saw 18" A spec rims on a 2nd gen & they were sticking out of the fenders a little. for the same price i could get 20s anyway. I'm trying to find 19s with the most lip possible for an 03typeS not lowered. What size width? And could someone tell me what offset is? i dont get it
Originally Posted by JLee87
would 17"x7.5" Falken Hanabi's fit... offset is +32?
Owner's Manual, Offset
1/ No one has answered Jack's question from September - what is offset?
2/ The owner's manual (2003 TL) gives very dire warnings about changing any wheel or tire specifications. I've checked a few online tire sites, and go through their "tire selectors" and come up with only "stock" sizing (60R16 205, 6.5 rims). So what gives with this? (I ask because I would like wider tires, better grip.)
Originally Posted by JackBauerCTU
Can you explain to me the offset?...
![Google](https://acurazine.com/forums/images/smilies/google.gif)
http://www.yokohamatire.com/utcustom.asp
"The wheel's offset is the distance from its hub mounting surface to the centerline of the wheel."
Offset is important so that if you buy a set of rims, your rims don't stick out beyond the wheel wells (and cause the infamous 'rubbing') Honda is notorious for having high offsets, so your choice of rims is quite limited compared to say, Toyota or Nissan products. A lower offset also enables you to get the 'deep dish' on rims.
6th Gear
wheel rim size
20x9's and a 45 offset is perfect for the 2nd gen tl's. tires:235-35-20 nittos 555. i had the rims custom made for the style .will post pics later
Derrick,
Thank you, making more sense (i/ definition of offset OK, ii/ make sure circumference doesn't change [much], iii/ more rubber could stress suspension components), but the remaining question is:
How then does one determine just what upgrades would be reasonable? Eventually I would need numbers. I'm presuming that because the S-Type has 215's on it that I could at least upgrade that far from 205's (and leave the other specs the same) - whether it would make a significant difference or not.
But another poster in the meantime has made a wilder modification (and promises to add photos soon) - how do people know what's going to be acceptable and what's not?
Thanks again.
Charles
Thanks again.
Charles
Most of this is legal mumbo-jumbo. Our cars are engineered to work within a certain range. The car computer detects certain factors and if factors are put out of whack, it messes up critical components like ABS, etc. That's why it's important you buy things like tires that have a circumference within 2% of OEM size. If you go wider rims/tires, you put more wear on suspension components. Things like that add up to the functionality of the car. Make sense?
I believe with the 235/40/18 tire set with 18x7.5 (+48 offset) rims, the life of my suspension will be premature. I've had ball bearings go a couple times on my passenger front (and replaced under warranty) and I doubt that was due to chance. Just something to keep in mind -- you want to look good and perform a little better or you want to play it safe? If you want to play it safe, pick a rim with the same dimensions as stock; pick the same aspect tire size -- pick these things but lighter than stock and your performance will greatly improve (handling, acceleration, ease of steering wheel feel, etc).
Hey guys...just wondering if this would work...appreciate your help.
My Mazda 3 has 17x6.5 wheels 52.5mm offset 5x114.3 with 205/50/17 tires.
'99 3.2 TL has 16x6.5 wheels 55mm offset?? 5x114.3?? with 205/60/16 tires.
Would I be able to switch wheels/tires from car to car just as they are now??
The Mazda wheels are quite new and sharp and I think they'd look great on the TL. My original TL wheels are very beat up and scruffy from salt and sand. I'd like to drive the Mazda in winter with the scruffy wheels and reserve my TL for good weather driving.
Any opinions. Appreciate any help. Thanks
everfeb99TL
everfeb99TL
everfeb99TL
everfeb99TL
Thanks REV-01
I forgot about the hub diameter or center bore
Mazda is 67.1 mm TL is 70.1 mm
Does this matter? I really don't have a clue when it comes to this stuff. Thanks
everfeb99TL
everfeb99TL
just curious, am i going to have any issues with my new tires. i purchased the michelin pilots sport a/s size "(225/45zr17)". All this talk about keeping the size stock is concerning me, especially after spending $800 bones. Right now my ride drives like a dream, with unbelievable traction & handilng. Thanks
Derrick,
That's great, thanks.
May I presume that the suspension components of the S-type are the same as my "plain" 2003 TL? In that case, up-sizing to at least 215's shouldn't be a problem.
Would such a small change make a noticeable difference?
Also, I'm using the Michelin web site for reference, it looks then like I might need to change wheels. (Yes, I've never done this before.) One tire, for example, at 205 is on a 16 inch rim and at 215 a 17, and the circumference increases by 5% - that's presumably too much. That must mean that the ABS and TCS and speedometer/odometer are different between the "base" and S-type. How would I get around that?
(The Michelin web site says that if one is thinking of varying from "stock" to consult with a dealer...)
I am thinking also very definitely of longevity and ease of maintenance - nothing very wild, as you can see. If I could get 225's to work I think I would be very happy.
Can you also clarify your phrase "lighter than stock"? Does "lighter" means "smaller numbers"?
Thanks again.
Charles
Thanks again.
Charles
There are no absolute answers to some of your questions. As you know, Honda has engineered our cars with 205 and 215 width tires in mind. I've only seen people go as wide as 235 on tirewidths (mine included) with our restricted choice of tires/rims...
... If you want to play it safe, pick a rim with the same dimensions as stock; pick the same aspect tire size -- pick these things but lighter than stock and your performance will greatly improve (handling, acceleration, ease of steering wheel feel, etc).
Yes those sizes are great for the tl. As long as the bolt pattern is correct
Agean Blue Bishes
1 Post
got some new / used rims. 18x7.5 with a 45 mm offset. what size tires should i get?
225/40/18
the widest tire would be ideal but i don't want to roll fenders or any thing. and i would like to keep it close to the stock diameter.
i am gonna be dropped on h&r 51858's
thanks
225/40/18
thanks
bigdaddyz822 (12-09-2011)
