Falken Ziex ZE512 or Falken Azenis
I got Type S rims and want the tires to be 235/45/17. I would get the Ziex ZE512 in W rating and the Azenis in Z rating. Which one would you choose and why. Also, should I go to 225 instead of 235?
The Falkens are good tires, so either tire choices would be good. It all boils down to how fast you drive, and will you use the extra grip the more expensive tire provides. If you answer yes to both, get the more expensive grippier tire. If you don't see yourself going that fast, or take high speed turns, get the cheaper tire.
I was searching for a pic of someone with the 235/45/17 falken ziex but wasnt successful. I am either going with 18's or this same set up as Stevenyi. We need pics of this set up...least I do.
JG
JG
