ES Radius Rod bushing...cracked!
Moog Radius Rod bushing...cracked!
I've replaced every part of my front suspension due to a clunk/clank this past fall. I didn't bother to check the RR bushings because I just installed Moog RR bushings about 2 years ago.
The clunk/clank came back so I figured, F it, I'll check em for shits and giggles and this is what I found:
The passenger side's nut isn't flush, so I'm assuming it's only a matter of time before it gets like this too. They were torqued to spec as well. I'm going back to oe(m) RR bushings.
Mr.Helpful Diagram
Wow im surprised, Your caster must be off by a few .
Question, did you install them like the service manual indicates ?
Reason I ask is most Accords and TLs that Ive done suspension work on I find that the bushings were installed incorrectly.
Maybe I over torqued this one? Either way, I'm tired of all the extra stiffness, I bought the rubber replacements tonight.
Mr.Helpful Diagram
I highly doubt it, even if it was over torqued it wouldn't change the stiffness of the bushing since it has a collar that stops the bolt from squashing the bushing flat.
I have had mine in for well over 100k miles and they are still in great shape.
It was just like the pic, with the larger bushing in the front:
BUT I did notice I had mis-matched discs/washers/whatever they're called. The rear bushing had a smaller one than the front...maybe I used the aftermarket one on the front and oem on the rear. Maybe it allowed too much flexing on the bushings? Or maybe I just had a defective bushing.
In any case...on to the next click/popping noise. Thanks guys.
the metal collar that goes inside it, did you reuse your stock one or the one that came with the new bushings?
emailnatec
29
09-28-2018 04:27 PM
BoricuaTL
04-08-2016 01:08 PM
DerrickW
11-15-2015 05:52 PM
