Comfort?
6G TLX-S
With the same tire model, the lower the tire profile (sidewall thickness), the rougher the ride.
Wider and/or lower profile tires also need wider width rims. First pick a tire brand and model, then go to Tirerack's individual brand page and look at the tire specs. There you'll find the minimum rim width recommended by the respective tire manufacturer for the particular tire size.
225s will fit inside the fenders on a gen2 TL
235 will require cutting a plastic tab in the fenderwell, and if dropped much, some massaging of the fender lip-edge profile will be in order~
On my 2001 TL 18x8 inch wide rims 235-40-18 General Exclaims and Tein SS drop 1.75 inches, the ride and handling is great, the wife enjoys the ride and the tires are way better than the OE mickyslips In My Opinion
tirerack has a conversion page for speedo differance
Going from stock 16s to this setup was a very small rotational distance change, actually it cured the 2mph fast reading at 70
MrHeeltoe
20
02-23-2023 01:54 PM
mlody
12-04-2019 02:11 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
