coilover question
coilover question
what are the more popular coilovers used for this car? i recently installed tein springs and discovered that i need to replace the struts, plus im just not really feeling the drop i got. should i spend the money on oem struts and another set of springs? or just switch to coilovers? how is the ride quality of coiloers compared to lowering springs? all help is appreciated. thank you...
The Dumb One
if you're not liking the height of the springs, replacing the struts will not help your cause.
coilovers are adjustable, and you can set them to your liking.
there are several reputable companies to buy coilovers from including Tein.
if you buy a set with dampening control, you can easily adjust comfort.
my struts are shot, they need replacement, im just trying to figure out if its more worth it to spend the money on coilovers, or buy new struts, and a different set of springs
3 pedals in my 99 TL
Yea it honestly all depends on what you want. Personally, i think coilovers are the best way to go. You have the option of adjusting the height plus with springs its a set height so you cant adjust the height. With coilovers though the ride quality depends on the brand. A good number of people get function&form coilovers because of the price and quality and adjustability. They give you a wide range of adjustability, have good ride quality and are affordable. Although im biased because i have a set of them id recommend coilovers either way.
If you buy the Koni yellow sp3 shocks you wont have to buy new springs, the Konis have adjustable perches to adjust the ride height even further.
i dont want the car slammed, just want to eliminate some wheel gap and even it out, i have 18's on and i live in NY most roads are shitty and during the winter, the amount of salt is unreal
And where he lives (as other members have found out and posted about) the salt and sand from winter use can take a toll on the coilovers making them impossible to adjust after a short time Its one of the reasons i wont run them where i live. Its happened to mine in the past.
MechEng
I would say yes they are. But only because they are easier to bottom out thus risking blowing out the shock. Stock shocks have a lot of suspension travel and can take quite a beating.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 07:42 PM
