best tire size for 18x7.5?
'03 ABP YA4-S 6MT
235/40R18 for the closest diameter to stock and a wide footprint
225/45R18 if you're worried about rubbing and are not going to touch your fenders
235/40R is the correct size, though (assuming type-s)
'03 ABP YA4-S 6MT
Originally Posted by bibledriver
I seriously doubt you will rub with the width and offset you described. I agree with 235/40 18
I figured by going 17 to 18 I would experience some rubbing. I just got my TLS and havent even received my plates yet. So I wanted to get the rims first then figure out how much drop I would need after the rims. 1.5 is what I was hoping to go to but I guess either way, i would get rub-age.
its easy to fix rubbing. I have 235 40 18s on my 01. It had 205 16s stock
check tirerack.com for what tires will safely fit on what rim width
Most drops by switching to coilover -adjustable height shocks like tein, are 1.5 minimum, unless you are just doing some aftermarket springs- you can get them with about 1 inch drop
Volks FTW!!!
i'm runing 225-40-18 right now, but when i need new tires, i'm getting 235-40-18 for a wider stance and feel.
unless you're slammed, you shouldn't have rubbing issues. but then again it all depends on your suspension too.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
