AGGRESSIVE wheel fitment question >>>
ok so i have a 03 type s Aspec ( stock 6.5 +55 offset ) n the car will have appx 3-3.5 inch drop
so what im tryin to do is get the xxr 526s
the front will b 18x9 +35 the rear will b 10.5 +20 the tires will have to b stretched for better fitment..
i did the calculations and at 10.5 +20 will be 16mm less on the inner side of rim and outer will b extended 86mm
i kno im going to have to roll my fenders n probably flare them>>>> this is my question how much (in inches) will i need to flare them n possibly the spacers in mm will i need, and how much camber help would be highly highly appreciated
thanks
thanks
that's the risk you have to take when buying aggressive wheels. i took the same risk on my 18x9/10 setup.
you will have plenty of space on the inner side so you have to run some serious camber and/or pull the fenders. how much you have to pull will depend on how much camber you are willing to run. run less camber = more pull, and vice versa.
nuldabz
09-03-2015 05:49 PM
