Advice and Questions for the Slammed TL's
I was wondering if, in order to prevent the rubbing, do you have to roll the fenders with a fender rolling machine? I'm riding on 19x 7.5 and i slammed my car all the way but even the slightest bump rubs so i raised it back up.
I was also wondering how do you know, with the Tein SS suspension, if both sides are at an even height? Do you just go by how many threads are visible or something?
That is all.
That is all.
I didn't really haveee to roll my fenders, I did have to cut off the bumper tab thing tho. The only time my rear rubs is when i got like 2 or 3 peeps in the back seat and then it'll rub a lil going over pretty decent size bumps. My front is dropped all the way down, but the back can still go lower, i dont want to go lower in the back because then the drop would be uneven. I doubt you would want the rear to sag also.
Your right, to make sure both are even, I count the thread lines that are left and go according to that..
Hope this helps. Good luck
P.S. What the hell is up with your user name? Why would you change it to GayTL? Are you gay or something? lol
but thanks for the advice, anyone got pictures of the bumper tab thing? I'm in class...
the bumper tab is right under the rear wheel well were the bumper meets the fender....its just this pastic rubbery peice that extends from the bumper into the wheel well about an inch
i just used a dremel and cut them off, and then sanded. rubs were gone. really easy fix and only took like 15 minutes to jack the car up, dremel, sand, and do the other side
im dropped 2 inches on 19s and got no rubs
BobbyGraham388
10-22-2015 05:05 PM
