Adding springs after new wheels & tires
Greenhorn
I inherited a 2000 TL that had no modifications whatsoever. This weekend, I replaced the 16" OEM rims with a set of new ones from a 2004 TL. Instead of the old 205/75R16s, I now have 235/45R17s. If my next move is to add some springs to lower the car slightly, what suggestions do you guys have for ones that will keep me from rubbing? I talked to someone about the Eibach Prokit, but I wondered if the 2.1/1.6 inch drops would create a problem for the new tires. Any suggestions?
go with comptechs... im sure a lot of people will tell you to do either comptech or H&R... i have comptech and i love it- the ride is still reallly smooth and i believe comptechs will give you the ride as close to stock than any other spring... i dont know about H&R because i never had them but listen to what people that have them have to say about it.. however, compechs are quite expensive- a new set running about 300 and H&R's are much cheaper... i have the same year as you so you might want to think about getting new shocks also and save on labor... which is wat i did, got hte comptechs with the Tokico Illumina's
good luck
good luck
Greenhorn
Thanks, man. I've done some reading throughout the forums and it seems like I couldn't go wrong with either the Comptechs or the H&Rs. I guess it was fate, though. I just found some 1 month old comptechs on ebay for $125. I think they're definitely worth the risk.
Moderator Alumnus
Dropping your car with those '04 wheels/tires will generate some major rubbing. The offset on the '04 wheels are much too low. Trimming the rear bumper tab will not alleviate all rubbing. Suggest you stay on stock springs.
Greenhorn
Even a drop of 1.25" in the front and 1" in the rear? I was hoping that was so conservative that I wouldn't have to worry about it with the Comptechs (110-135s).
oh ooppsss ... sorry didnt see you swithced your rims... my bad Lawaia... hmmm but even then, it shouldnt be a problem, no?? cuz its only 1.0 and 1.25 which then settles to like 1.25 and 1.5 at most... you might want to chek up on that Tmax... not sure about these 04 rims and stufff- i was under the impression you were still on the 16" stock which is wat i have....
good luck
good luck
Greenhorn
Okay, I haven't messed with springs yet, but I just got in my Tokico Illuminas. I know what's been said about the offset on the new rims I've got, but I've got to rid myself of this "stump jumping 4x4" look. From front tire to fender edge is about 4 fingers. On the rear, it's almost three. Surely, there is something I can do about lowering the car with these rims. Suggestions?
A modest drop would be H&R OE springs. I think they drop the car 3/4" ... not much but you won't have to worry about major rubbing or camber issues. The "ideal" way would be to get coilovers (eg Tein SuperStreet, etc) such that you could adjust height AND ride firmness.
But the '04 rims with such a low offset ... maybe you're better off to leave it stock height? Post pics to give us a clue what you're dealing with.
Greenhorn
Yup. As a result, I sold the ones I got off ebay. This time I'm thinking H&R or Eibach. BUT, I need to know how far these rims can be lowered safely. I don't want them tucked under the edge. I just don't want to look like I'm driving a Jeep sedan, you know? I`ll try for pics tomorrow.
Greenhorn
Finally...pics...
#1 - pic of front wheel with gap
http://tmax.photostep.com/image/240084244
#2 - pic of 4 finger width (approximately 3 inches from top of tire to fender)
http://tmax.photostep.com/image/240094789
#3 - pic of rear wheel with gap
http://tmax.photostep.com/image/240109876
#4 - pic of 3 finger width (approximately 2 1/8 inches from top of tire to fender)
http://tmax.photostep.com/image/240112349
Moderator Alumnus
You're in dire need of a drop. But as we said earlier, you can't drop it too low cause you will rub with those '04 wheels. I would suggest H&R OE's. Anything lower and you're asking for trouble.
Greenhorn
Moderator Alumnus
Originally Posted by Tmax67
Could I mediate a slightly larger drop (say, 1.5" or so) through an adjustment on the Tokico Illuminas I'll be adding? Or would that only affect the firmness of the ride?
Greenhorn
Depends on the application. The parts from a V6 Accord will fit the TL (1999-2003) but the thing is the V6 Accord isn't as heavy -- therefore, you'll get more of a drop on the TL than advertised. That's why there is a variance in drop for the "same" springs.
Most people with the H&R OE on this board report about 3/4" all around. Just be sure to ask for the springs specifically designed for the TL. (I don't know part #)
Greenhorn
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
