5 mm spacers...worth it?
I want to widen my stance a bit, I feel like my wheels sit inside the fender too much. I have CL-S rims (17x7, +55). Based on the "Will It Fit" thread, I can go to +42 with a 7" wide rim. So I wanted to add a 10 mm spacer. But I haven't found any 10 mm spacers for our car, only 5 mm and then 15 mm, and higher. So I looks like I'd only be able to use the 5 mm. Do you think it's even worth it to get the 5 mm spacers? Or does anyone know where to get 10 mm spacers?
6G TLX-S
With the 5mm spacers, the wheel nuts will also be grabbing the wheel-nut bolts 5mm less.
So I bought generic 10mm spacers since H&R and Project Kics don't make a 10mm. I understand I will need new studs, but I was wondering, how do I replace the studs? Also, I bought hub centric rings that I thought were for the spacers, but it looks like they are for wheels. Here are pics:
Does anyone know where to get the correct hub centric rings? Thanks.
Originally Posted by princelybug
Just to answer the OP's original question: IMHO, it's not worth it.
6G TLX-S
Do the longer studs come with the spacers ?
The hubcentric ring will do you no good if it wont sit in the spacer AND wheel.
6G TLX-S
So the wheel nuts are grabbing the OEM wheel studs 7mm less.
Sorry for the delayed responses everyone, I just got back from a trip to Japan. The spacers are JDM LOL.
Nope, I need to get those separately.
Yeah I need to find one that is 64.1 mm that fits in both.
Anyone know where to find them? And also, how are the studs replace in the wheel hub?
Thanks.
Thanks.
So I bought a pair of 10mm Kics Project spacers that have new studs already on them. I was worried about the original studs extending past the spacer, but it turns out that it wasn't a problem for me. I have the OEM CL-S rims, and they have an empty space in between each of the stud holes. Therefore, the original studs can sit in that empty space and don't hit the rim. Tomorrow I'll show pics of what I mean, as well as the final stance. I know it's only 1cm per side, but IMO it is worth it for the cost and ease of installation. BTW I had to cut tabs, but also keep in mind I have 225/50/17 tires.
You can see that the original studs extend past the spacer, which could hit the back side of some wheels. However, the OEM CL-S rims have spaces in between the stud holes, so the extra portion of the original studs can sit in that empty space.
(image of back side of OEM TL-S rim):
(open areas circled):
Tomorrow if it's not raining I will take pictures of the new stance.
