350z brembo rotor as replacement for discontinued 1 pc rotora bbk disc?
Old 10-12-2014, 01:20 PM
3 pedals in my 99 TL
mugenspire's Avatar
Hey all,
Recently upgraded to a set of Rotora BBK, the 1 pc disc that is discontinued. I also realized the rotors are rusted and not runnable on the set I purchased and also know that this 1 pc rotor is discontinued by Rotora.
I have been looking for a replacement set and was thinking that the 350z drilled/slotted brembo rotor that we use for the RL BBK conversion would be a direct replacement since Rotora only sells the 2 pc disc now and it is incompatible with my model and they are both 13" discs (the 350z disc and the rotora disc).
Not sure if anyone has tried this before but I'm 99% sure it will work and plan on ordering a set in hopes of a test fit and replacement.
Any help would be appreciated if anyone knows or could chime in.
I've spoke with Excelerate about this and informed them I'd be ordering a set as well to test it out since they were also able to provide me with replacement set of brake pads since my Rotora brake pads were no good as well.
- Teo
Old 10-12-2014, 03:47 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
If length is correct the only issue now is thickness. Do you have the specs for it? In worst case the 350z rotors are thicker and you will have to run them down to spec and it will work BUT if the 350z Rotors are thinner you will have a lower brake pressure all the time.
Old 10-12-2014, 04:10 PM
mugenspire's Avatar
Okay cool that makes sense. Yea I'll have to look up the specs for the thickness then cause I don't have either. Let's hope for a match!
Old 10-12-2014, 10:50 PM
mugenspire's Avatar
been doing a lot of reading and its pretty hard to come by 330x23mm rotors which are the Rotora specs.
the 350z brembo rotors are 324x30 so I don't think that will work.
Decisions, decisions...
Old 10-13-2014, 12:21 AM
mugenspire's Avatar
Another question and alternative idea!
Since the rotors are not cracked or warped and only rusted, wouldn't I just be able to clean them up to run them? Looked into the product 'Metal Rescue' and feel confident after watching a few videos and reading reviews in soaking the rotors for a few hours to cure/clean them up.
The only reason I've been looking for a replacement set is just because of the rust, no cracks or breaks on the rotors themselves, I just assumed I wouldn't want to run a set that is rusted and was lazy to clean it at the time.
Thanks!
Old 10-13-2014, 01:31 AM
Skirmich's Avatar
We'll seems the alternative is pretty expensive right now. You should start saving up now that you know is a PITA to get a replacement.
Old 10-13-2014, 02:05 AM
mugenspire's Avatar
Yea because basically...you have to upgrade to the 2pc disc now for like 1k + and trade in your old set. Fuck that. I would've just went with another brand/setup if I knew that was going to be the case.
But no worries, I always work with what I've got and I'll make this set work and it'll be glorious hahaha. I plan to clean off the rust on the rotors and get a new set of brake pads and call it a day!
Thanks for the help as well man!
Old 10-13-2014, 02:32 AM
Skirmich's Avatar
Yeah no prob! Hey at least they will look awesome installed. I so want 4 Pots but the money is tight so my Legend Calipers must suffice for now.
Old 10-13-2014, 02:41 AM
mugenspire's Avatar
I feel that man! At least you're on Legends! I've been running weak stock brakes for 4 years so it's time for a nice upgrade LOL
Old 10-30-2014, 03:07 PM
TunaTheFish's Avatar
So for the RL BBK mos you need:
RL calipers
350z drilled/slotted brembo Front rotor
Custom Brackets by Fastline
Didnt mean to jack your thread Sorry
Old 10-30-2014, 03:32 PM
Be a better driver
RedRyder's Avatar
Rotora left a ton of customers out in the cold when they stopped supporting their 1pc rotor BBK’s. A lot of people invested in them, and Rotora stopped producing replacement rotors, refusing to back their product and telling people they could only trade in their old kits for new 2pc rotor BBK’s. There are numerous threads here with people desperately researching solutions. I myself talked to several vendors and got close a couple times to finding a rotor that would work, but it was still a dead end. Spent a lot of time scouring the internet.
I was talking with Casey at XLR8 last year and they went to Stop Tech, but nothing came of it. They suggested two factory rotors for other cars that wouldn't work iirc. Another vendor was pretty helpful and we found some late 80's/early 90's Saleen rotors that were close, but not close. Two other vendors said they could reproduce the rotors, but the price wasn't worth it. Anyway Rotora could have easily continued to offer the rotors, but chose to screw people over instead of offering what's called customer service.
But I'm not bitter or anything...
Old 10-31-2014, 06:07 AM
mugenspire's Avatar
Originally Posted by RedRyder
Rotora left a ton of customers out in the cold when they stopped supporting their 1pc rotor BBK’s. A lot of people invested in them, and Rotora stopped producing replacement rotors, refusing to back their product and telling people they could only trade in their old kits for new 2pc rotor BBK’s. There are numerous threads here with people desperately researching solutions. I myself talked to several vendors and got close a couple times to finding a rotor that would work, but it was still a dead end. Spent a lot of time scouring the internet. I was talking with Casey at XLR8 last year and they went to Stop Tech, but nothing came of it. They suggested two factory rotors for other cars that wouldn't work iirc. Another vendor was pretty helpful and we found some late 80's/early 90's Saleen rotors that were close, but not close. Two other vendors said they could reproduce the rotors, but the price wasn't worth it. Anyway Rotora could have easily continued to offer the rotors, but chose to screw people over instead of offering what's called customer service. But I'm not bitter or anything...
Yea found that out after searching and speaking with XLR8 as well. Thank god for metal rescue and sand paper to clean up the bbk rotors and make them look brand new! All I need now is a new set of Rotora brake pads and I'm set for this bbk repaint/rebuild/install kit!
Old 10-31-2014, 12:16 PM
Skirmich's Avatar
RL calipers
^ Pretty much! that's all! And the ability to convince your old lady to spend 600$ bucks in brakes
TunaTheFish (11-08-2014)
Old 11-04-2014, 08:52 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Are the rotora calipers 2 piece? (ie separate in the middle)? If so you could run separate them, make a shim to go between the 2 pieces and run a thicker rotor like the 350z
Old 11-06-2014, 12:53 PM
mugenspire's Avatar
Unfortunately they are the original 1 pc. caliper, but that would be a great idea if they were 2 pc.
Old 11-07-2014, 12:15 PM
fsttyms1's Avatar
Are they are 23mm thick? That seems to be awfully thin. Stock TL fronts are 28 with a min rating of 26
Old 11-08-2014, 01:00 AM
mugenspire's Avatar
Yea 330x23mm is the specs on the rotora rotors. Kind of weird they would make specs for the TL that's thinner than the minimum rating?
Old 11-08-2014, 09:15 AM
Be a better driver
RedRyder's Avatar
Spacing the caliper is an interesting idea. But wouldn't that be a problem when it comes to piston travel? And you'd have to extend the lines that span both sides of the caliper
Old 11-08-2014, 11:08 AM
Skirmich's Avatar
^ Shouldn't affect piston travel since you are giving the space needed to fit the new bigger rotor (Should remain almost the same).
The caliper brake divider line is a simple copper tube which can be retro-fitted from hardware store pieces.
Old 11-08-2014, 04:24 PM
Be a better driver
RedRyder's Avatar
Slipped my mind the extra width wouldn't be there since the rotor is wider, duh. As long as the retrofitted lines are secure/air tight yea that should work.
Something else that would be affected is the wheel spacing.
yesSIR-S
05-13-2016 05:42 PM
jmoney2001
09-11-2015 12:07 PM
asahrts
09-04-2015 05:55 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: 350z brembo rotor as replacement for discontinued 1 pc rotora bbk disc?
