Pirelli P7 205 60 16 H rated versus V rated
Old 12-07-2017, 08:26 PM
asb32952's Avatar
I dont understand the big difference in the prices of these.
Can you?
Amazon Amazon
Amazon Amazon
Amazon Amazon
SuperBuyTires.com - Your Shopping CartPirelli Cinturato P7
205/60-16
SKU: PCT2519
MPN: 2007600
QTY:1 2 3 4 5 6 7 8 $234.00X
205/60-16
SKU: PCT2519
MPN: 1178900
QTY:1 2 3 4 5 6 7 8 $342.16X
205/60-16
SKU: PCT2519
MPN: 2253300
QTY:1 2 3 4 5 6 7 8 $411.84
Old 12-07-2017, 08:50 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
The basic difference is the speed rating; what car are you putting them on?
Old 12-07-2017, 08:54 PM
asb32952's Avatar
Daughters 2001 tl commuter w/ 165k. Im thinking the H rated wont make a difference with 70k rating.
Old 12-07-2017, 09:00 PM
Latent car nut
horseshoez's Avatar
The only thing to consider is what speed rating Acura recommended for the car when new; if it was V then in some states in the U.S. it is illegal to use lower speed rating tires than the car is capable of achieving. By and large running H rated tires won't make a hill of beans in difference in ride, handling, or safety here in the U.S., however, if there is an accident and a nasty ambulance chasing attorney is hired by the other side, she might be held liable because of incorrect equipment.
Personally, I could care less, even though my TL is capable of hitting speeds significantly higher than the 128 mph rating of H rated tires, the odds of my even hitting 100 here in the U.S. are somewhere between slim and none, and if I found an H rated tire which met all of my other criteria for tires, I wouldn't hesitate to buy them and have them mounted.
Old 12-07-2017, 09:15 PM
asb32952's Avatar
Daughter likes to drive 65 in a 45 etc. She wears out brakes pads and tires fast. But at least she helps with brake pad and oil changes.
I try to tell her to coast to a sale green light.
30 years with big brown and back in the day I had a front tire recap separation without loosing air on I-95.
Hard to keep it in the lane, I was lucky.
Yes they can use recaps on the front for vehicles under 28000 GVW.
But they use new fronts on the airport run.
So, I dont give a damn on H rated for this application.
Thanks for stopping by.
Old 12-08-2017, 10:43 PM
asb32952's Avatar
I am thinking of these now for $76 shipped after coupon. 600 utog rating. Hope they arent as noisy as they are on a 2009 TL. Yes, they are V rated for 149 mph. Walmart charges $10 each for mounting, lifetime balance and rotation, I believe.
https://simpletire.com/bridgestone-p...6-147110-tires
Pirelli makes two different p7s in the H rated
One at 260 treadwear rating for $67. Cant use the coupon for under $300 total.
https://simpletire.com/pirelli-p205-60r16-2007600-tires
The 700 utog rating for $95 after coupon.
https://simpletire.com/pirelli-205-60r16-2253400-tires
Old 12-09-2017, 07:28 AM
Latent car nut
horseshoez's Avatar
Just a "For what it's worth", I put the Pirelli Cinturato P7 All Season tires (the P7s with the 260 rating are summer only performance tires) on my wife's GTI and they were fantastic in all weather conditions and never got noisy. I will be putting them on my TL as soon as the current set wears out.
Old 12-11-2017, 05:00 PM
Darksyne's Avatar
I have had those exact tires H rated on my 2000 TL for the last two years and honestly those are probably the best all seasons you can put on that car if you're commuting. They perform very well, are super quiet and the low rolling resistance helps highway fuel economy.
They aren't a performance tire so I wouldn't waste money on the V rated since all it's for is for top speed and I even under steered the car a couple of times when really pushing the car.
Im getting rid of them only because I'm upgrading my wheels and getting dedicated summer tires but as for all season Touring tires the P7 cinturatos are the best H rated tires you can get for the TL.
jbwua6
15
12-06-2013 05:14 PM
Aviography
09-24-2009 10:12 PM
Rice1304
05-09-2001 11:10 PM
Rice1304
01-26-2001 06:17 PM
Quick Reply: Pirelli P7 205 60 16 H rated versus V rated
