255/35/18
255/35/18.
Anyone have a spare one laying around they want to send me to see if i can get it to fit???? Lol...
Im going to be hopefully testing and figuring out what i need to make them fit this week. I just need to buy one on Ebay or find a tire shop around here that has one. Ill keep you updated.
Oh and im working on another mod at the same time. As soon as it gets delivered this week ill show it too.
Ordered a used 255, should hopefully be here this week. The Cough.... Odyssey bumper..Cough... should be here wed
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
Your Friendly Canadian
Received 1,485 Likes
I thought tire width didn't affect the size of the contact patch
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
How could it not? There is more rubber on the road. If that were the case The ZR1 wouldnt need a 335/25-20 on the rear and could get away with a 205 to save weight. A tire 10" wide has more surface area on the ground than a tire with 5"
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Just something I read a while ago. Apparently a wider tire means a wider but shorter contact patch. There are still benefits to having a wider tire, but the size of the patch stays the same. Could be wrong. I'll try to find the article.
First read this on a different article, but here's one that provides some insight. Been reading a bunch of other stuff on the topic, but they're mostly forum debates. I can link those if you're interested.
Check this out:
http://performancesimulations.com/fa...on-tires-1.htm
Juicy stuff: contact patch area = weight/tire pressure.
Width obviously affects the shape of the contact patch, and a wider tire is probably better for performance driving or when under extreme load which makes sense if you think about it.
Check this out:
Now to see if it fits
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0755.jpg)
Fatty
Looks good. Will you be doing a lot of driving on these particular tires, or are they strictly for test-fitting?
Reading > Me.
I need to find somber with a fender roller just incase. I have done it with baseball bats but I like the rollers. I can do a little stretch with them too.
Wonder if I can get 275s on it
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Rears will just need a fender roll.
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0768.jpg)
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0771.jpg)
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0769.jpg)
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0766.jpg)
Fronts? Its going to be close.
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0772.jpg)
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0770.jpg)
And yes, its lowered. Its not going to be lowered any more. Its less than 2 fingers
![](http://i265.photobucket.com/albums/ii206/fsttyms1/IMAG0774.jpg)
This is what im worried about, when i have the front rolled up in the fender from cornering ![what](https://acurazine.com/forums/images/smilies/what.gif)
![](http://i265.photobucket.com/albums/ii206/fsttyms1/Acura/TL21.jpg?t=1303610364)
Would it be possible to run a little more negative camber up front?
Nitto Invos (again) or
![](http://dagostinoracing.com/images/Nitto-Invo.jpg)
Conthttps://acurazine.com/forums/showthread.php?t=815082inental ExtremeContact DW
![](http://www.ridelust.com/wp-content/uploads/ContinentalExtremeContactDW_1.jpg)
Im leaning to the Conti's
