235-40-18 tire for 2000 tl
Old 04-08-2005, 02:57 PM
8th Gear
jacky1230's Avatar
Hi, wondering aset of 235-40-18 on a set of RH C-5 a 45 offset will fit on my TL?
Old 04-08-2005, 04:34 PM
derrick's Avatar
Are you lowered?
I'm on OEM Type-S shocks, (rusty) silver Comptech springs with 18x7.5" (+45 offset) Volks with 235/40/18 Toyo Proxies4 ... occasional rubbing if I'm really loaded with people in the back. If you're not lowered ... should be fit OK. Don't know if the OEM shocks may cause rubbing or not, though ...
Old 04-08-2005, 09:30 PM
8th Gear
jacky1230's Avatar
I am riding on a set Koni shock and H&R spring. Will it rub?
Old 04-08-2005, 09:37 PM
Dragging knees in
Pure Adrenaline's Avatar
18x7.5 ET42, 235/40/18 on my car. They rubbed like hell (lowered on Tein SS) so I had to roll the fenders and cut the bumper tabs. I still rub if I'm taking a corner hard and hit a bump by myself in the car.
Don't do it unless you're moronically dedicated like me. I just loved the wheels and was determined to make them work. But I would hate to see anyone else go through the same trouble.
Old 04-08-2005, 10:03 PM
8th Gear
jacky1230's Avatar
Thanks for the help!!,
I going to try to put it on, see it will fit.
Old 04-08-2005, 10:04 PM
8th Gear
jacky1230's Avatar
What is best tire and wheel size for my 200 tl?
Old 04-08-2005, 10:20 PM
Dragging knees in
For a 200 TL, try stone wheels.
It's usually best to go one size up from the stock wheels/tires, and match the overall diameter. I'm not familiar with the stock setup on the Premium model. 205/55/16, was it?? If that's right, then, I would recommend 225/45/17 for a sportier, but still comfortable, ride.
Old 04-08-2005, 10:26 PM
8th Gear
jacky1230's Avatar
I also have a set of 17" OZ supperleggera wheels.
Can i put a set of 225-50-17 tires on them for my tl?
Have any one putted on?
Old 04-08-2005, 11:06 PM
TLover8888's Avatar
i was wondering also...i have TL-S rims on my 2000 TL and i was wondering if i put 225/50/17 on those rims, will it rub? BTW, the stock TL-S tire is 215/50/17
Old 04-08-2005, 11:23 PM
8th Gear
jacky1230's Avatar
TLover8888.
So, how did TL-S wheels and tire fit in your car? Do you have space left in the rear?
Old 04-09-2005, 01:21 AM
TLover8888's Avatar
TLover8888.
they fit perfectly...no problems. direct bolt on. yes, i have space in the rear b/c there's no rubbing.
snorf
11-04-2019 06:44 AM
Robospinner
22
09-24-2015 08:47 AM
huskynut
09-24-2015 08:10 AM
Mike Bertram
09-10-2015 09:27 AM
fallacy
09-04-2015 10:15 AM
Quick Reply: 235-40-18 tire for 2000 tl
