22s on acura tl 01
Can i fit 22s on a 01 acura without a lift kit?????? or i got to lift it and was the max i can go up to besides 18s i know the standard rim is ummmm 16s so was the max
Standard is 16 on Base and 17 on TL-S
BUT 22? LOL that wont even fit even if you beat it to death... It wont clear the Knuckle and if you install spacers it wont fit the fenders by a good margin... Size criteria: 18s is a nice and good fit 19s depends on offset 20? Pull Fenders and Spacers 21? Nope 22? Now you are kidding. |
^hey, if he wants to ruin his ride, LET HIM! :snicker:
you guys are real funny must be order cats lmao i need young Black folks(no offense to anyone) for this One cuz they know how to get it done and what to do......and why is it so many of them if its impossable nothings impossable
That is not the STOCK suspension man.. I hope you realize that.
Just by looking at them they have Custom Front; Lower A-arms, Custom Upper A-arms, Custom lift kit, Custom Rear Lower A-ARM, Custom Rear upper control arm. I can assume they have more money put into the suspension rising kit + wheels + tires than the whole car cost. |
Originally Posted by Skirmich
(Post 15994674)
There must be shops that do that sort of thing? I really do not know anyone in my years in this forum that have pulled that off, You will see people often here preferring function over looks so I kinda got stuck in my mind the parameters for Reasonable wheel sizes that work in our TL.. +21inch area? not really common around here since it requires a lot of work.
Since I have been on it, this site has pretty much always been function over form. So sure it can be done, but I don't think anyone here has done it.
i think im just going to do 20s lol
go big or go home OP. ride or die bad boys for life :toocool:
Acura's dont have great automatic transmissions!!
I wonder how long the transmission last under those heavy ass loads! |
(Post 15995938)
(Post 15996059)
That's a problem for the future. :O
mind over matter...and the transmission doesnt matter |
I bet those 22's would fit with minor trimming to the bumper, removing the fender trim and rolling the fenders. It definitely wouldn't need a lift kit or anything but some major alignment tweaking. Not at ALLLLL my style but its very doable without any major work as described.
Lets do the math. There's 25.4mm per inch. A stock tire being 205/60/16 OR 8.07 inches wide at its max, then taking 60% of that is 4.84 inches tall. So, adding 4.84 inches to 16 inches makes 20.84 inches from top to bottom of the tire from factory. We all know how much the car can be lowered with just any normal lowering spring so its not hard at all to imagine removing 2 inches of wheel gap for a 22" wheel and another inch or so for those stupid rubber band tires they have to run. They'd work with no problem, just a bit of trimming and adjusting for daily use and you're on your donking way. |
We are in the process of putting 22s on a 2003 acura tl type . We are using blocks in the springs, 1 1/2 inch spacers, and we have had to cut. The problem we are running into now is turning, the tires scrub the firewall when you turn too much so I'm thinking flap disc some metal off and then paint bit don't know yet how much I can grind off. Funny experience, definitely doing it as a pun but still doing it
https://cimg4.ibsrv.net/gimg/acurazi...1294fe4f00.jpg |
Ballin'
just don't turn :co:
I feel sorry for the car; it is so embarrassed it wants to hide from itself.
(Post 16667193)
