18x9, +30
#124
would it require a fender pull to have 18x9.5 +35 in the rear i know the fronts would be good. just askin since you have air ride. im gonna run ksports with camber kit in the rear.
#128
prototype
hahaha good one lol
i didnt have to have pulled fenders, i just rolled em with a baseball bat. so that was free. well, i bought the bat from salvation army for a dollar and ive rolled over 12 different cars with it, so... it was near free :P
tire size dude, 18x9.5 225-40-18 will work.... for more stretch (but less meat) 225-35-18 would be sick too. or 215-40-18... might look too small for your liking tho
#130
Unregistered user
its compromise.
without a pull, more camber, with a pull less camber. more camber = more toe; more toe is bad, more camber isn't (to an extent).
beefier tires means more camber or a pull
skinnier tires means less camber, or even a pull and even less camber.
u get my point.
u get my point.
#134
prototype
yeah i put an 8mm on oem studs and it works, but rarely if ever did i roll around on em. good for show purposes tho.... nightmares of wheels flying off prevented me from dailying on em all the time
#136
prototype
on coils, w/ the kit set to -3 or so rear camber, with 225-35-18's, id say you could get it to go w/OUT the fender pull (jus roll)
buuuuut im not sure. ive seen similar setups done tho, thas what im basing this off of
#139
yea camber in rear to adjust inwards i want 40 series but if that means excess wear in the rear then i might get the pull. we'll see what happens. great info guys thanks
#142
im going to have pic's soon of tsw bremma's 19x9.5 +25, 245/40 Rear, 19x8.5 +30, 225/40 front.
they aren't for my car, they are for my brother's lexus...but we are going to test fit them on my lowered TL for the hell of it. (wish i had a rear camber kit)
#143
Unregistered user
without a camber kit you WILL NOT fit the rear. you'll need at least -4.5 ESPECIALLY if they don't have stretched tires.
trust me, i had 9.5 +24 225/35/19 tires with -4.2 camber and shaved fenders and they poked out 10-15mm. so in your case, no camber kit you will not fit them.
#147
6G TLX-S
Try not to drive with them after test fitting them on, because the car will handle like crap with extreme understeering.
#149
Meridian
I have a question for you all, I am planning on running 225-40-18 tires on this setup:
front: 18x8 +48
rear: 18x9 +50
I know the front will be okay with no rub, but im worried about the rear. I already cut tabs, I have not rolled fenders yet, will I need to do any further modifications to the rear to make the 18x9 rear wheels fit? I plan on getting the fenders rolled. Would I need to run a neg. camber setup with a +50 offset?
front: 18x8 +48
rear: 18x9 +50
#150
prototype
front: 18x8 +48
rear: 18x9 +50
front: 18x8 +48
rear: 18x9 +50
18x9 +50 on 225-40-18 or less and you'll be ok, with rolled fenders. and of course, your fronts will be fine (i suggest even spacin' em out 5mm just for a li'l flusher fit)
hope that helps... at least this is what i conclude based off the 9 wide +35 i had before, on coilovers. without rolled fenders it wouldnt have worked... and i doubt your +50 will fit w/out rolled fenders either, unless you're kinda high (which would look crappy IMO) or you go with smaller tires than 225-40. and even then, i still think you'd wanna roll fenders.
#151
prototype
#152
prototype
volly p.s. man, youre gonna run 225-40 all around, even on the fronts? you may wanna consider a smaller size down for those 8 wide fronts, to match the look. i went 215-40 on my 18x8's and 225-40's for the 9 rears...
#153
Meridian
volly if you look at my pics on the previous page, the pics when i didnt have air ride (tein-SS instead), the silver wheels rears on mines were 18x9 +35 w/ 8mm spacer, +43 without. i DID have rolled fenders, and cut tabs, did NOT have neg camber setup (no camber kits ever for me)...
One more question tho, does stretching the tires make the rim more vulnerable to pot holes and misc. road wear damages on the ground?
I am def. doing 225-40-18 all around, I was even thinking 235-40 just for the rear, but that may rub even with fenders rolled.
And yeah im def. going lower in the summer (on the tein basics), I would like to have a small pinky finger gap in all 4 wells.
#154
prototype
yeah more stretch means less area of contact for the tires... youre just gonna have to be careful, is all. 225 on 9's is less rubber on those than the guys who are running 235's, etc.
that s2k setup should be fine, before i got my 8/9's i was eyeing a set of 8/9 work equips off an s2k down here, but didnt have the $ at the time. woulda been nice tho. the offsets of those were similar to what youre looking at, i think his were 48/53 or something. up to you on the 225 fronts, if you like i can try dig up some 215 pics, its not a HUUUGE difference and may be better for you going low and still making non-rubbing turns...
#155
Meridian
If I do run 235 with the 9" rear at the back, I would rub even with fenders rolled?
#156
prototype
yeah you may still have rub troubles. stick with the 225, it's still got plenty of meat, looks better, and will fit better also.
on a side/funny note, yesterday i saw the red s2k w/ the work equips i wanted, wheels still on. guess they never sold em lol
#158
prototype
![](http://a325.ac-images.myspacecdn.com/images01/106/l_994e37a97fa3c8da95f903893ae459ac.jpg)
![](http://a742.ac-images.myspacecdn.com/images01/120/l_52c44811ba3d6d95102231b0dfbb204d.jpg)
sorry man these are the best two pics i can find... other than the pics i already posted. these tires are federals... theyve got a mild stretch, best of both worlds kinda setup as it looks good and will help you fit the 9 rears, yet still arent overly stretched/ "unsafe"
#160
I have dead hookers in
so right now i am saving up for my wheels and i just wanna double check..
WORK VARIANZA F2S
19x8 +43
will that size and offset work good or should i go with a different offset?
i am going to lower my car with an Eibach pro kit just so you know i wanna lower it if that will affect the offset i should get
WORK VARIANZA F2S
19x8 +43
