18x9, +30
#41
that will work fine if your dumped, rolled, tabscut, almost identical to mysetup...but your stock height? get it dumped... rolling your fenders... theres a lip on the inside of the rear wheel well, it gets rolled so its flat, to add more tire clearance.. the tab cutting has been discussed a bunch, basically you notch the rear bumper for more tire clearance..
#44
at 4.0-4.2 neg. camber its poking about 10-15mm out which is what i wanted. the fronts have something like -0.3 camber and pokes 5-10mm. course i'm on 225s. no pix yet, i just readjusted camber from 3.6 to 4.2, with 3.6 it was poking around 15mm-20mm, but with that i should have gotten a fender pull.
something like 19x8.5 +30 or +35 would be flush in front, rear should be around the same if u run almost no camber.
nice should look pretty fuckn sick..
#45
Need my Daily Fix of AZ
For everyone wondering about the G wheels, i put my buddy's 350z Volks wheels on which are 18x8 et +30 with 225/45/18 tires (not 100% sure on the tire size)
Results are....
(click Pics)
http://www3.telus.net/willdathrill/DSC00017.JPG
http://www3.telus.net/willdathrill/DSC00015.JPG
These are the both the Front Z wheels on my car.
For our cars, we would have to cut the tabs and roll the fenders for sure.
Results are....
(click Pics)
#46
#47
Results are....
(click Pics)
Results are....
(click Pics)
we should use this thread to compile all wider, lower offset wheels for 2G TL's.
if my car was lowered i would take pics of the G35 wheels on my car, but until its lowered...the pics would not be much help.
#48
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
![Gold Cup](https://acurazine.com/forums/images/smilies/goldcup.gif)
#49
![Sick](https://acurazine.com/forums/images/smilies/sick.gif)
#51
dont know about the center cap's
#64
thanks man, now i know what kind of stretch a 225 looks like on a 9" wide wheel.
have you thought about work XD9's, 18x9 +32?....or are you looking for a lower offset?
also, what adjustments to your camber have been made?
#65
im looking for a x10 wheel actually for the rear and camber wise im not as flush as i want to be right now my works are at -1.7 camber but im planning on changing that to probably 0 and well see how that looks i want a poke look i doubt i can run x9 +32 in the front without it sticking out a little to much right now my front wheels are perfect imo sorta flush but the rears i need to work on
#67
Low & Slow w/Dubz On My
can you guys start posting pictures, along with your spec's?
i purchased a set of Rays G35 wheels with tires to use as a refrence....they are now for sale.
8.5wide, +33 pokes out about 1/2"-3/4" in the rear
8 wide, +30 poke's about about 1/4" in the rear
i want to order a set of 18x9, +30 wheels, but i need to see some cars actually putting these width's and offset's to use to gain a little confidence in my future setup. (i cant afford to purchase another set of wheels just to see how they fit.
anyone want to buy some G35 wheels? i have them on ebay (user id= gripfab, item # 220321592392)
#70
Mr. 2tone
![](http://img210.imageshack.us/img210/8924/photoshoot1of2008037tb5.jpg)
its a bigger difference since u have 18s in the front n 19s in the rear
love the car tho
#78
i agree.. thats why teins suck, get the rears lower then the fronts.. i have the replacement springs for the front, these are old pics from last april/may.. that one pic the car sitting weird, so it makes the front look a lil awkward
