Transmission Rebuild in Toronto, any shop suggestions?
So the dealer is charging me $7450 to replace my tranny... :what:
I'm going to call different dealers in Toronto to see if this is right. I'd rather rebuild it for $2000-3500 and buy extra warranty. Can anyone suggest any reputtable shops they can refer me to? Thanks |
wow they were 4000 not long ago- do you need extras like all the motor and trans mounts and ecu and a major service??? Or is it the dollar shrinking the problem?
For straight rebuilds look for name brand shops with locations across the country- so the warranty is good anywhere...aamco- cottman in the states Ask how many Acura or other make Tiptronics they have done- if you are not the 5th or later keep looking! dont be the test subject or it will take 3 tries to get it close to right $2500-3000 woud be normal price for that parts and labor |
I don't know if this helps but here are the codes they pulled
P0700 Automatic Transmission System P1740 4th Pressure Switch Failure I don't think i need a new tranny... |
What dealer are you getting a quote from, sherway, down town...?
If you want to do it on the cheep check out active green and ross or Mr. Transmission. I can give you a reference for active. Last time a friend of mine in a tranny there it was $2600. That was 2006/07 though. |
Stupid 5 minute rule.. I should be able to edit WHENEVER!!
Get a second opinion. If you want a private mechanic to look at it, I can also recommend someone who works on a range of imports. If you want another dealership to check it out, call down town acura. My contact there has left but they have a great service department. |
I'm going to call different dealers in Toronto to see if this is right. I'd rather rebuild it for $2000-3500 and buy extra warranty. Can anyone suggest any reputtable shops they can refer me to? Thanks Try this guy. Saw him on cp24 AUTO SHOP |
Hey Rob,
I don't mind paying between $2500 - 3500 as long as these guys are reputtable and have done Second Gen TLs before. It would be great if you could find out from your friend how his/her tranny is holding up since the rebuild. Thanks!
Still which dealer did you goto to get the $7500 quote?
I went to Power Shift Transmition in Woodbridge and they still havn't fix rough shifting and everything I went there for. The owner name is Ralph and he's a peace of ****. Car was covered under dealer warranty. I'm still not done with them, they will have my transmittion running like new....
It was Acura Sherway.. I talked to the service manager there after I got the quote from the advisor because I thought that it was over priced and he was a prick. He said "What's wrong with that price?"
Goto down town acura and get a quote from them. I have an email into my buddy in the GTA.
Thanks for your reply FamusFace. I actually talked to that guy Ralph he didn't really mention that the TL has tranny problems so I kinda knew that he hasn't worked on any TLs before.
A couple of the mechanics I called had something to say immediately after I mentioned to them that I had a TL. He said "After I rebuild the transmission you won't have to come back to me and fix it again." Wow, what a big fat lie. Plus they quoted me $1600, too good to be true.
Thanks Rob, will do.
Okay I called them and told them I was quoted $7245.40 and they said it seemed about right. The dealers only replace them they don't rebuild them.
Well ask them if they want the business because you want to pay $2700 for it.
Also call Acura Canada to try and get some help with the cost. |
Acura Canada are being bitches and won't help me cover the cost. I can't prove to them when the tranny oil was changed last. The previous owners doesn't have any old service records for the car.
$2700 for it. Also call Acura Canada to try and get some help with the cost. |
I will hopefully have something for you soon, but I might be delayed with recent events. |
No problem Rob. Thanks for the help thus far
