Torque Converter Lock Up System
Old Apr 21, 2011 | 12:56 AM
Oh Shaith's Avatar
3rd Gear
I recently had my check engine light go on in my 2003 3.2TL so I took it in to have it checked out by my mechanic. The diagnosis came back as an error code 740- in the transmission for torque converter lock up system. They checked the lock up solonoid and everything looked okay so they cleared the code. Has anyone ever had any issues with their torque converter? I have approx 90k miles on this tranny. Had it replaced in 2006 after it blew out due to a mistake made by the dealer I serviced it at. But any way should I be concerned? The car seems to be driving and shifting just fine.
Old Apr 21, 2011 | 01:59 AM
01tl4tl's Avatar
drain a small sample and ck the drain plug- it will have crud and metal on it--its magnetic for a reason
if the clutches are failing it will clog the torque convertor outlet screens
Old Apr 21, 2011 | 12:15 PM
fsttyms1's Avatar
Usually once you have a tq converter code its too late and a trans rebuild is in the bear future. Has the light come back on after them clearing the code?
Old Apr 25, 2011 | 09:54 PM
ac5320's Avatar
The Brown dit
my car had given no issues, was driving perfectly fine, then all of the sudden if I pressed down on the gas, the car would speed up a tiny bit, and then stop and just the rev would increase without the car increasing speed. I pulled over, shutoff the car and waited a few minutes and tried again. It drove, fine for a few miles but then went out for good. To the point where the car would not go anywhere. I had it towed home, where I have moved it once by putting it in drive, and the car went on it's own the 10 feet I needed it too. I checked the code, and I got the same code p740 - torque converter clutch malfunction. My car has 165k miles and I am going to fix it. I am went to Howard transmissions website, they sell clutch converters (reman) as well as transmissions. Am I going to need both? or just the transmission? or can I get away just by getting a clutch converter?
Old Apr 25, 2011 | 10:26 PM
Skirmich's Avatar
Thats a Doomed Transmision for Sure, Sorry Dude....
"Don fsttyms1" Diagnosed the same thing when I askd him and My trans Failed next day (Started to Slip Gear) then 2 days later it wouldnt even Move out of 2nd Gear.
Im Only wondering when my 740 will Show up again Hope it doesnt happend anytime Soon, I really depend on the Old´TL.
I need to buy an 06 Accord Tranny to feel A lil´bit Careless but theres No "PESOS"...
Old Apr 25, 2011 | 10:43 PM
ac5320's Avatar
The Brown dit
yeah that's what I thought. It sucks big time, I had bought a a 350Z two days earlier as a summer car thinking my TL was running strong and would last a few winters or so. This will be the 4th transmission in this car I think....
Old Apr 25, 2011 | 11:28 PM
Skirmich's Avatar
WoW That Sucks!
Im running my 2nd Tranny Still @ 179K, Replaced 1st Tranny around 115-120K I forgotten Exactly When but I remember having made my First Timing Belt Service just Before my Tranny went Caput! Sucks Nuts.
My 2nd Tranny was Rebuilt by a Private Shop, Still Shift Smooth as the Day I got It Back!!
I Just Hope the Clutch Packs the shop Installed are a Lil´Bit More Stronger to last More than the OEMs.
Old Apr 26, 2011 | 02:55 AM
01tl4tl's Avatar
what happens is: the clutch disc material comes off and clogs the torque convertor- so it cant pump any fluid to make the trans operate
requires trans rebuild, and new or rebuilt tc to fix
Sorry, cant just pop in a t/c and be fixed
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
Frathora
Sep 28, 2015 11:29 PM
Junior Noboa
Sep 21, 2015 06:28 PM
