TL 1999 Help with list of problems.
Hi Friends, here are the list of repairs that my TL 99 needs.
1. Transmission slipping just cold , was rebuilted and dealership is going to take care of it.
2. Steering Wheel pump, I will buy the Oring for the hose, fingers crossed. Mechanic told me it was the power steering pump around $250, but I'm positive with o-ring replacement.
3. Gauges lights dimmed, I saw a diy, i'will take time and try to fix it.
4. Noise crack in the passenger side, the Dreaded Air Mix Motor, diy by Skirmich.
5. Alarm and locks acting weird. I can open door locks with key, but they don't close with the key, I need to close them on the door, the same for the passenger side.
6. Driver's back door locked. I need to remove the door panel.
7. Check engine light on.
Thanks a lot for your help!
And can you identify this?
I wouldnt know what one would look like, but I believe that is a GPS tracker.
IMEI #'s are found on cell phones and also, that little tracker has the letters GSM which stands for Global Systems of Mobile Communications.
i believe its a GPS tracker from a used car lot.
small car lots or dealerships use GPS tracking and even kill switches for deadbeats.
meaning if you dont pay the car note, they can turn off your car and find it.
wouldnt Lo-jack be branded?? meaning it would say Lo jack somewhere.
and LoJack is a GPS unit, exactly what i said. lol
it's a GPS unit.
adreano17
09-29-2015 08:48 AM
