Tips to improve gas mileage
Do ive been on this website and noticed people talking about getting 300+ miles out of a 2003 acura tls and i have a 2003 acura base model and only get about 210 miles to a FULL tank and ive always thought it wasnt the best but any tips to help change that or is it normal? Ty for your time
210 miles on a tank? What kind of driving? I am in horrible stop and go daily and I always get over 300 before the light comes on. Have you been able to do a full tank of only highway/freeway driving? I usually get around 400 on a tank if I'm doing a road trip. Mileage has for the most part been pretty consistent in the 12 years I've had the car.
How long have you had the car, and what is the maintenance history? |
I agree with @SuperGreg, both my J-30 equipped Accord and my J-32 equipped TL easily get 300+ miles on a tank for mixed daily driver mode driving, and will get into the high 400 mile range on a road trip. Said another way, something ain't kosher with your car, errrr, unless you're sitting in traffic all of the time.
Miles per tank isn't always the most accurate. I'd fill up then drive until you're at 1/4 tank or so, then refill it and divide the miles by the gallons. Also note what % is city vs highway driving. I doubt you'll get much more than 22 or so in town, 28 or so on the highway. If it's significantly less than that then I'd be concerned. It seems the 2G, 3G and 4G all get around the same mileage. I get about 25MPG with around 60/40 City/Highway driving. I got closer to 28MPG in my 3G but it was a 6MT and I did more highway driving with it than my 4G and it didn't have an AT leaching power.
As far as mechanical stuff goes, try cleaning the MAF or MAP sensor (not sure which the 2G uses), run a can of Gumout Multi-System Tune-Up and make sure your spark plugs and O2 fuel/air ratio sensors are working well. Spark plugs aren't too expensive to replace but the O2 sensors can be. And it's difficult to tell if they're getting old and less accurate. I'd start with measuring mileage more accurately then seeing where you sit after that. |
I started adding to my previous post and then got called away from my desk. Here is the basic content of what I had been writing:
So to be more clear, when I say I get xxx miles per tank I generally measure that when the gas light comes on.
OP, how is the car's power? Does it seem normal or sluggish? Another user had a frozen caliper pin that was causing drag and killing their mpg. I would get an OBDII scan tool and install Torque on your phone, and check your fuel trims and O2 sensor readings to see if they look normal. |
Originally Posted by SuperGreg
(Post 16249431)
Originally Posted by horseshoe
(Post 16249535)
The problem with this advice is I cannot tell you how many times folks have done that, gotten "normal" readings, and yet the issue was still the upstream O2 sensor.
(Post 16249535)
(Post 16249874)
If the O2 sensor is bad enough to be causing issues I don't see how you could have normal fuel trims. Maybe they were not checking long term trims?
(Post 16249340)
Difficult to imagine, " i should mention my gas milage was noticeably worse before i "changed" the spark plugs and cleaned out the gunky a** intake manifold " MPG "noticeably" worse, than 12.5. Did you follow the FORUM recommended procedure, for cleaning the air intake system? Did you notice, which specific plugs, you removed from the engine. Which specific plugs, did you install? Re: " kind of clinking in low rpms or idle maybe valves?????? ", would it be possible, to post a video, of this "clicking". How many miles, on your car?
Originally Posted by Puffyacura
(Post 16250056)
Ive had this acura for about >1 year and the maintenance record is non existent i bought the car from a 23yr old with 4 kids and it was HORRIBLE only for aout 1.3 k i had to straighten the subframe from a previous crash and that stopped eating my tires as soon as i got it i did a fluid change on almost everything although i should mention my gas milage was noticeably worse before i "changed" the spark plugs and cleaned out the gunky a** intake manifold there is also a kind of clinking in low rpms or idle maybe valves??????idk but if anyone can make sense of any of this thank you very much! I plan to get this car running O.K. and find myself a clean title tls of the same year
(Post 16250119)
Based upon this description, it sounds like the previous owner used a K&N type of oiled filter, a filter type which is absolute crap for street applications and they don't filter worth a damn. Now you've remediated the effects of the modified intake, and are still experiencing poor fuel economy, the two most likely places I'd look are the previously discussed O2 sensor, and (I believe also already discussed) brake calipers. After a drive of a few miles down the highway, stop and wave your hands around the wheels, if one or more are REALLY warm, you have dragging calipers.
Adding to my list of unknowns i removed A (1) muffler The other day out of boredom and had to run to the store and it smelled like sulphur? Like it was a nasty smell when i accelerated. Also previous owner had oem intake BUT was cracked and the air filter was upside down😵. |
Originally Posted by frankjnjr
(Post 16250092)
(Post 16250328)
TBH i just grabbed extra spark plugs in my shed and screwed them in they looked similar and im PRETTY sure i didnt strip the thread also i will try to get a vid on this thread tomorrow and my car has 163 k miles
(Post 16250330)
A very dangerous thing to do, just because plugs "look similar" does not in any way mean they are mechanically compatible or any where near the correct heat range for your engine. My recommendation is to yank those plugs and put in the factory recommended plugs.
(Post 16249150)
Also make sure the EGR and Intake passages are clean, it really helps if it's never been done. Free up the car's breathing, keep the maintenance up to date with OEM fluids and parts and try to reduce friction, drag, and weight wherever you can and these cars can surprise you with the mpg. |
(Post 16249346)
Hey frankjnjr, you mentioned the forum-suggested method of cleaning the air intake - got any more info on that so I can find it in a search? I'll be cleaning my IACV soon so I figure I might as well try to get everything else while I'm there.
Originally Posted by Arkady
(Post 16251298)
http://www.acurainspired.com/gallery...=1914&uuid=290 start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes. if your engine is any thing like the 2nd gen baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe) it sounds like alot but its really easy should take about a hr to do " ******** I can't seem to find the thorough Induction System cleaning, i mentioned. There are several, in depth videos, on Youtube, regarding the complete (Cleaning) process. Perhaps, these are the ones I recall. It's been four years, since I did mine. Hope this helps. |
Mpg
I have a 2003 cl type s, 6 speed and want better gas mileage, these vehicles have a 17 gallon tank and should get 29 mpg hwy, so should get just under 500 mpg on hwy , of course we do the spark plugs , tires psi, air filter , pcv , etc but still not what it should be , thanks for all info
Originally Posted by Irishstout1
(Post 16398837)
FWIW #1, just because a tank is 17 gallons does not mean there are seventeen USEABLE gallons in the tank. FWIW #2, I don't know if the CL Type-S is capable of returning the same fuel economy as a 3G TL 6MT, but last fall under nearly ideal conditions I went something like 534 miles on less than 16 gallons in my TL; the mpg number was something over 35. |
