Ticking Noise
Ticking Noise
I have 2 wierd noises coming from my car that are not normal. the 1st is a loud errrrrrrrrrrnt(I know bad interpretation but best i could describe it) about 20 sec or so after starting car and does it 2 times then goes away. Next is a high pitch ticking/ whining noise that only happens when car is moving sounds like possibly from right side. Any ideas wut theses are?
I think mine has the same issue.....sounds like its coming from underneath the car right underneath the rear door somewhere. i cant figure out or pinpoint where its coming from..but it sounds like a bomb or something...its not a sharp ticking sound...its more of a "dull" sound...if that makes sense..any help would be great.thanks... 99 TL
You should get one of them at about 5mph, and another about 15mph I recall... It used to bother me, but after discovering that it was normal, I don't pay too much mind to it anymore...
As far as the whining noises, I cannot help you there... Good luck!
Ya i did some reading and the whining is possibly 1 of the wheel bearings is in need of replace. Im glad to know the other 2 sounds are normal. Im taking my car to the dealer on monday to get the whining checked out ill let u guys know what happens.
05 C230K & 09 135i 6MT
If you ARE rolling, this is normal since you have VSA. On VSA cars both systems test, meaning you'll experience two of the whirring sounds. On ABS/TCS TL-Ps it only happens one time.
If the noise happens from a wheel.. is it a whine, or is it a screech? If it's a screech it's probably just a brake pad wear indicator - you need new pads. If it's a whine, you might want to look into wheel bearings as mentioned.
Originally Posted by fsttyms1
Thats the evap canister. Its normal.
Hey thanks for the help...is there any way to get rid of that noise..can i replace it? It is really annoying...when its sitting still....
If you hear the sound from under the hood area its the purge control selonoid
Hey thanks for your help. It doesnt seem like its coming from under the hood of the car, sounds like its coming from underneath the rear door somewhere...but i cant pinpoint where its coming from. i guess ill take it to the dealership and hopefully they can figure it out!Thanks again
the purge control selonoid can echo underneath the car and can be heard inderneath the rear doors on occasion. open your hood with the engine started and listen up towards the top right u will hear some ticking, then go by the rear door ur hearing it from and if it is the same sound then it is just the purge control selonoid echoing. mine does it and dealer said its normal.
the first pic i posted its coming from #5. many have that issue (the EVAP Canister)
Because some dont like the noise. Not all do it, but its a common issue.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
