TCS light only....
TCS light only....
I know there are many post with people asking about TCS and CEL, but I only have the TCS light on, any way to figure out what could be causing this since I can't pull a code since the CEL is not on? Thanks!
Did the TCS light just randomly come on by itself.....or was it the result of some manuvering skills ? If nothing was done to engage the TCS, check the "R/C Mirror" fuse (7.5A) located within the driver's side fuse panel. Is the switch on or off for the TCS/cruise ?
If nothing seems to help, the ABS/TCS control unit is located under the passenger side's kick panel. With key off, remove the wiring connectors to this unit, then with the connector out, turn the key on. If the TCS light still doesn't go out, then there's a short somewhere in the wiring causing the light to stay on. Maybe a wheel sensor ?
you did ck the switch right?
mine has done that twice,first time,transmission took a shit,second time,it was a plug by the bottom of throttle body facing bumper,was unplugged .pluged in and light went off
