TCS activates all the time!!!
Everytime I start from a stand still, the TCS activates itself. It is so freakin annoying. I already had an alighment done. The last shop that installed my XS headers overtightened my O2 sensor to where it fell off. I had it weld on last week. 2000 TL with 93458 miles, dropped with Teins H-tech no camber kits install.
When you say it activates every time, please describe what its doing
Do you feel the brake on one side being applied to reduce wheelspeed versus the other side?
Is the yellow dash TCS light flashing when this happens or steady or on all the time?
deal with it
Originally Posted by MikePA
Then turn it off. Simple.
yes just press the button on the left side of the wheel that has TCS on it......and TCS should light on the cluster......this means that you have turned off your traction control........now if it staying on at all times even if you press the TCS button......thats a different issue
I guess I'll try that first, but it does not eliminate the problem right. I have to turn it off everytime I start the car, no? It flashes when turning in either direction and when going straight from a complete stop. I can't tell which side is being activated, but the brakes are activated to slow me down.
And you're not doing burnouts right?
This is just normal human style driving on dry pavement?
Gentle accelleration as if Mom were in the car?
The default setting is ON when car is running
So dash light OFF
Sounds like speed sensor problem- giving bad or no info to computer
Done any work with the brakes or shocks recently?
So dash light OFF
The wire from the speed sensor to the back of the wheel is semi-delicate and can easily be pulled apart from inside its covering when work is being done.
If its not getting a signal from one side, the TCS speed computer hears- I am going 10 MPH on the left and 0 on the right = apply left brake to gain traction
TCS only works up to 18 MPH and then stops so thats why you regain control
Easy way to see which side
Toss some water in the street
drivin like a soccer mom
Does that mean you are on the cell phone while 8 children
throw things about the cabin and sing songs you really dont want to understand?
I have seen a few on the roads that looked ready to freeeeakout!
If you have a set of ramps- put it up and look for a wire with black covering,
near the back of the brake backing plate, may be loose or look ok
It appears you had a shop/someone do the rotors for you, so it would be their responsibility
Or did it start after the alignment?
Check auto parts or dealer- I think someone in LA recently had same prob and it was $35
Check the wiring, it looks like it is still intact. I was revving the engine and saw the power steering fluid bubbling in its container. Is that suppose to happen?
