Stop light switch!!!!!!!!!!
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
My 99 3.2 needs inspecting and it will not pass unless the lower brake lights are working. I purchased new bulbs - still not working, purchased stop light switch - still not working but the part could have been a defect, has anyone had this problem
Does the 3rd brake light work ok?
You replaced the brake light fuse to be sure right?
And did the old bulbs look ok
or have you had no brake lights for a while and are just fixing it
Corrosion, bad connections bad ground! etc fall into play
You need a friends help and a 12 volt test light
Check for power at the switch
Check for power at the bulb connectors
Originally Posted by lokee99
If the third brake light works then its not the switch. you gotta check the wires from back lights.
If it were the switch, he would'nt be able to shift out of park.
Sharroll - I have the same problem - I replaced the brake light switch, but the lights (and the release for the transmission) are still not functional. You mentioned you replaced the wiring harness? How big a deal was this? Do you remember what the harness cost?
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
