Still getting misfires with all new coils & plugs
Old Jan 31, 2013 | 02:17 PM
hurricanejosh's Avatar
3rd Gear
Car is a 1999 TL with 277k km
Codes 0300-0306 & 1399
Issues started last year with one failed coil and a EGR port recall kit.
Since I've been replaced the plugs (NGK Iridium) and the remainder of the coils as they've dropped off on at a time.
I'm still getting the misfire codes, last time I reset the ECU it was 3 days of driving before I got one though.
I've tested the new coils with a multimeter, 2 from the dealership are 16000 ohms but the other 4 I ordered online and are 10000. Is that within spec?
If that's not the problem, what's my next step?
Old Jan 31, 2013 | 02:41 PM
fsttyms1's Avatar
Have you done a compression test. Other things would be bad injectors
Old Feb 3, 2013 | 05:06 PM
3rd Gear
compression test came back quite consistent 170psi wet & dry on all cylinders
Old Feb 3, 2013 | 08:15 PM
3.2TLc's Avatar
Hey Hurricanejosh, the '99 TL's had lot's of EGR passageway problems with clogging up. Try going back in and ensure that everything is clean.
Check with the DIY sticky for more details. Also may want to consider a quality fuel system cleaner. Inspect all the wiring and vacuum connections.
Old Feb 4, 2013 | 01:42 PM
3rd Gear
thanks for the tips. the EGR was done a year and 15000km ago. would it really be clogged up again already?
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
