Smell of hot plastic (maybe burning oil), loss of oil, but no evidence of lost oil
4th Gear
I don’t see any lost oil dripping out from under the engine (no visible leaking and no oil spot). However it is noticeable that the oil is going somewhere when checking oil levels on the dipstick. It is using a pretty decent amount of oil too.
I believe the smell I thought was a slight smell of burning plastic or oil was related. However I only suspect this because I noticed/suspected the smell has grown worse as the oil consumption has also grown. Thus why I believe they may be related.
There is no evidence of oil in the coolant, nor exhaust. It is not “burning” oil in the engine. I suspect it is dripping somewhere I’m not noticing and getting hot enough to burn off or whatever. No oily residue in the tailpipe, nor black smoke.
Im at around 200K miles. I plan on changing the timing belt and water pump very soon. I have been tossing around the idea I’ll change the crank and cam seals while I’ve got the engine open like this, but I don’t think this will be the resolution. Because I don’t see any oil in this area (not that I really can see there until I get that side of the engine apart).
I've wondered if the rear main seal is leaking and dripping onto the exhaust or something similarly hot enough to hide the leak. Does this sound like this is the problem?
I also may need to change the accelerator position sensor, but I’m not sure if that’s the issue there. It was giving me an intermittent problem with a loss of smooth running when there was heavy rain after first starting, but that seems to have gone away.
About three months (give or take) before I noticed the smell I believe to be related to the lost oil I changed the valve cover gaskets and seals. I changed them because I had an oil fouled spark plug and coil (plus a misfire code). Haven’t had the same problem after changing the valve cover gaskets. Although admittedly I didn’t check the spark plug and coil again. I’ve just assumed it’s good because I’ve not had anymore issues with the misfire.
Did you check:
- The cylinder heads between where the valve cover gasket lies and the exhaust manifold? especially the back one where it is hard to reach
- the cam-thrust seal covers? those things should be shiny aluminum...it could leak out there and down to the exhaust manifold.
4th Gear
Youre certainly helping me narrow in on something!
Did you check:
I think I need to clean the oil that I see, make sure it’s got plenty of oil, and take it on the freeway and check everywhere again.
So it seems to be leaking exactly where you’re talking about on the left and right sides (essentially at the front and rear side of the engine because it’s sideways for the front wheel drive) just below the valve covers. The sides toward the radiator and firewall appear to be bone dry. The underside is covered in oil. I honestly hadn’t checked below before because it doesn’t drip oil when parked anywhere to my knowledge/notice. I’m not sure about the cam-thrust covers. I’ll have to figure out what/where those are exactly and look at them. I loose oil essentially as soon as I drive on the freeway or otherwise at higher rpms. It manages to always keep enough oil to read low on the dip stick (just above the lower dot). Enough to make me nervous but not enough to prevent me from driving.
4th Gear
4th Gear
Really not sure
So I don’t seem to be able to locate the leak. It is also far slower/less than I originally thought. I have a much cleaner engine and don’t smell the burning smell. I guess I’ve just got to keep an eye on it for now and maybe catch it if or when it gets worse...
Probably leaking only when cold? that's what I was seeing....6 months later the engine was covered in black soot/grime.
I noticed that the age of your car is pretty much on par with mine, I had 200422 when my transmission went out (to a state where I could no longer drive it more than 50ft). I recently swapped my transmission with the AV6 and now have 50 miles added on BUT...while I was doing that swap I too noticed how dirty the engine was and found that oil leaks usually originated from 3 places on my car:
- the rear main seal-mine was perfectly fine but i still replaced it to be proactive and well, my transmission was already off. mercy on those that have to replace this seal with a transmission that is perfectly fine.
- the top of the engine-this could be any seals related to the valve cover, which there is a "kit" for or the CAM thrust covers-ALL of these seals on my car needed replacement; the rubber was hard as a rock and crumbled when I removed the seals.
- the front of the engine-the oil pump seals OR dipstick (possibly from when I changed my timing belt last time and didn't replace the oring) I need to do all this work still and it shows up as a very slow leak onto the bottom of my oil pan with no dripping in my garage.
Just curious @whitetiger5 Did you do the transmission swap yourself or had a shop do it?
My TL is 19 years old and has 172K on it. Transmission was replaced under warranty in Nov 2006 at 61K miles.
I DID do the transmission myself with all the info I found on this website to guide me along the way. 1500 miles now and I've moved on to redoing all the steering, suspension and soon paint knicks with the money I saved by going with the AV6 instead of a rebuilt install by a shop.
Knicee
10-30-2017 07:25 AM
05TLbase
02-24-2011 05:15 AM
