right headlight
right headlight
i got a lil delay problem with my right headlight. everytime i start my car and turn the headlight on my left headlight comes on and my right one start blinking and then turns on and sometimes it dont even turn on at all till later. do i need an igniter or a ballast or some...... anything will be appreciated
thanks
thanks
Try swapping bulbs between the left and right sides. If the problem follows the bulb, you need a new bulb. You'll need a tamper-resistant Torx T-20 to access the bulbs. The service manual also recommends that you disconnect the battery before replacing the bulbs.
If you do have a bad bulb, replace both bulbs to ensure a matched set. The bulbs change color over time.
Bob
Bob
AmplifiedDetails
09-24-2015 02:55 PM
