Hi,
My 2002 TL's navigation screen is damaged and dim, I've looked through many threads about replacements but considering that I'm over 10 years late to the party, I cant find anything reasonable. Is there an aftermarket screen that was discussed and I missed? Or is there a way to fix the damage? Considering just doing a navigation delete at this point but can't find a dash near me.
you can always buy a replacement on eBay fro $50-$150.
or if there Is a pick and pull in your area, much less than that.
three options:
leave as is, use the AUTO button with temp setting to control the HVAC
replace the entire dash area with the non-nav interior and regain the manual control of the fan and A/C compressor lost in solution 1 above
replace the nav screen with a working part from a junk yard and regain full control AND vintage navigation functionality.
I replaced mine with that from a junkyard, in the end I mainly use it to control the HVAC fan speed and A/C; sometimes the map Is nostalgic to look at.
