Real Engine Seal
MUCH bigger than you!!
Real Engine Seal
Anyone had their rear engine seal replaced? Cost? Also, anyone in the Kentucky area know of a good mechanic....I got an estimate from the stealership and they said it would be close to $1K
![what](https://acurazine.com/forums/images/smilies/what.gif)
going to be pricy, its all labor. They have to remove the trans to do it. should be a 1 day job though.
They quoted me about 8hrs. of labor at $90/hr. That's $720 in labor alone....
F!!!!!!!!!!!!!
F!!!!!!!!!!!!!
yep, while removing the trans is easy, it just takes some time. Dealers that have replaced the trans quite abit can do it in around 4 hours (the techs tant have to do it alot) Ive had mine out in 3 hrs in a garage. Its just all labor unfortunatly with about 45 min of actual work for the part itself tops
UGH!!! This sucks!!!! Thanks again, man. I appreciate the insight.
