programing remote
05 C230K & 09 135i 6MT
Yes you can use a third remote. IIRC programming a remote involves something like waving a dead chicken at the car and doing voodoo chants, but that could have been misinformation.
Seriously, though, you can use the remote but I don't know the programming sequence. It is posted on the board somewhere, search around.
![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
Keyless entry Remote can be program by doing the following, you must program all remotes at the same time,
else the remotes not included in the programming will not work.
Make sure the codes in the back of the new remote matches your old stock remote. Some key fob may look the same
but won't work with each other. Be sure to have all Key fobs you want working with you when you do this.
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock button.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock button.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock button.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or
onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter
lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter
code is stores. Make sure you program all transmitters you want working within 10 seconds of each other.
Ones not included in this programming will no longer work.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
***make sure the serial number on the backs match.....Program at your own risk***
The TL keys have the chips in them, I found this but havent tried it yet..let me know if it works for you:
Originally Posted by TL_Fo_Life
1...your new key
2...a MASTER KEY (one with the remote in it)already programmed to car.
to program the transponder- (thats the immobilizer part)
sitting in dr. seat, put the master key in ignition, and turn to on.engine OFF. press the gas pedal 5 times to
floor and release. now press brake 6 times (press and release)
remove master key from ignition. install new key and turn to on...engine off. press gas to floor once. now wait.
the security light will blink for about 45-60 seconds, then it will go off if you did it correctly. once the light
is off, car should start.
'02 TL Type S
I am about to do this as well. After a quick search I cannot find any information on how programming the thhird remote effects the cars functions like memory seats.
I have two mem 1 remotes and a mem 2. Any thoughts on how having three will effect my TL-S?
try it and find out
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
'02 TL Type S
Finally got a chance to do this. Using the instructions found searching here it was easy and fast.
I did discover I could only get two different remotes to take at a time. But it didn't seem to matter what combination.
For the record I have 2 of the TL Memory 1 units and a MDX memory 2 Unit. THe MDX unit does not have a trunk release button but works great. I guess my extra unit will find a drawer untill it is needed.
joflewbyu2
10-08-2015 11:16 AM
SinCityTLX
10-07-2015 01:24 PM
