Problem with rear doors
Old Jan 22, 2022 | 02:58 PM
Kbanksta03's Avatar
Hello I’m a new member. I signed up because I’m having some problems with my car and seeking help. I have a 2003 Acura TL S. About two weeks ago, the rare doors would not unlock whatsoever. It was like that for two days, then it started working again. Today I tried to put the key in the driver door and it wouldn’t turn. I had to unlock the car from the passenger door. Once inside, I noticed the rare doors won’t unlock again. What can this be? Also my gears just started getting stuck in park no matter how hard I press the brake the gears don’t shift down unless I press down the button beside the stick. 🤔
Old Jan 24, 2022 | 04:21 PM
whitetiger5's Avatar
Hi! Welcome...Sounds like there are two problems:
  1. The rear doors are not unlocking.
  2. Your not able to shift out of park no matter how hard you press down on the brake pedal.
About item 1: is it just unlocking only? or both lock/unlock? if it both rear doors or just one? also: are you talking about using the key fob or turning the key in the drivers door to lock/unlock...or are you actually saying something mechanical is preventing it from locking/unlocking? I'm guessing it to be electro-mechanical and the door lock/unlock solenoid; but not sure of that if it's more than one door as that would be rare they all fail at the same time.
Item 2: there is a switch above the brake pedal that locks/unlocks the shift lock. when you press on the brake that switch activates a solenoid in the shifting area that can be heard. do you hear that?
vtec22
Mar 15, 2011 05:44 PM
mmade22
Jul 28, 2010 12:27 PM
JMitch4031
Nov 22, 2007 11:06 PM
JMitch4031
Nov 7, 2007 08:11 PM
contraryan
Apr 18, 2005 05:13 PM
