Power steering leak, then lower arm?
I'm having a steering pump leak and is bad, as bad as the edge on the tire is scratching the tire because the tire moved really close to the edge, drivers side is 3 fingers gap, and passenger side 2 fingers gap.
What do you think, maybe just lower arm?
Thank You
Thank You
![](http://img.photobucket.com/albums/v654/Fanaticibanez/tire.jpg)
Mr.Helpful Diagram
Radius rod bushings are worn or the lower arm is bent.
Check the the bushing first, its lets than $10 for both if I remember.
Left or right side is similar, remove the lower plastic cover.
01tl4tl (05-24-2014)
mike from annapolis
05-07-2017 08:21 PM
