No AC at Idle
No AC at Idle
Hi Guys, I searched around on the forums and couldn't find anyone with a similar problem.
It just finally got hot down here in SC, it hit high 80s during the daytime, so when I went out to start my car in the afternoon it was blazing hot in the car and I cranked on the AC. I was waiting for my friend to come out and I noticed that even after 5-10 minutes there was no cold air coming out. When i drove off, the cool air started coming, but as soon as I stopped at a traffic light the air became as warm and humid as the outside air.
I'm hoping it's just a small issue, like low fluids, but I wanted to see if anyone could help diagnose my problem. Really hope it's not major, I don't have enough money to completely overhaul my AC system right now, but living without AC in the summer months would really suck =/
Thanks in advance guys!
Im having the same issue with my girlfriends car. Also, neither one of the radiator fans are working..... If she turns the heater on, car temp runs ok, but if she doesnt, it starts to overheat. Sorry to highjack your thread......
S E L L
You either have a bad fan relay or a bad radiator fan switch. If you turn the A/C on does either of the fans turn on?
S E L L
good answer, the condensor seems like its not working correctly. if u really want to find out the leak, find a shop who can use nitrogen to draw the refrigerant, and fill the system with nitrogen. turn up the pressure close to max and check to see. not sure if our refridgerant uses pag oil with dye to checkl, would be easy.
ultimately if u cant find a leak on the condensor or any signs of the fan relay or switch bad, u would have to do a pressure test with the machine/sniffer/dye test.
I called a local acura dealer and they want a $95 diagnostic fee to check my refrigerant level... where's a good place to get this checked out, possibly for free? Seems like something that shouldn't cost that much.
I'm probably just going to go to the store and grab a recharge kit, which includes a pressure gauge and everything to do a recharge... only problem is, how do i know what the correct pressure is? is this spec in the manual, because I couldn't find it. anyone know this information?
6MT Someday..
If you dont know much about it I wouldnt recommend you messing with it. R134a systems are very sensitive to charge levels, if you overcharge it can mess things up. Take it to a local shop-theres nothing Acura patented on your a/c system that a decent shop cant handle. Good luck
DerrickW
11-15-2015 05:52 PM
