NEW member here need some help !
hey guys, just wanted to say wassup to the forums. Just bought myself a black on black 2002 TL-S. Has a few scratches but the back bumper has like 3/4. My question is the fog's dont work for some reason, is this a common problem? What should I check as a fix?
Also i was told that the driver's side shock might need to be replaced and the car just feels a little low on the front drivers side, and the air is low on that tire too. Wondering wherer can I get that used or new or should I just change out all 4 ?
Only thing is I just bought the car straight for 10.5k with 80k miles and pretty much am broke Good deal or not?
Did you check the bulbs to see if they were good?
With the miles you have you should just look into new shocks all the way around. KYB and tokico blues are cheap oem replacements that are better than stock
The fogs there is a little access panel under the bumper to get to the bulb.
Suspension all depends on where you get them from. he KYB's are like 60$ a piece. Labor call around to your local shops and see what they charge. It shouldnt take more than 2 hrs labor so dont let them charge you more
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
lanechanger
10-13-2015 10:56 AM
