Need Help: Stop Light Relay
I burned out this parts today. It is coming off the driver side taillight assy. I think it is a stop light relay (cuz my stop light does not work). I went to Autozone already and they do not carry this part. I need the relay and the connector (cuz they melted together) right away, I don't want to get ticket for this.
Can someone point out where can I get this part? I don't want to go to the dealer cuz the closest one is about 35miles away.
ChairmanMaoSaysRTFM
two things i will interject....
unless you order it online you may HAVE to go to the dealer, because i don't think anyone sells these connections and relays otherwise.
any warranty left on your TL? the fact that the relay melted denotes a defect which should be replaced under warranty.
i hope you get it worked out. you may be able to go to a junkyard and pull a relay from another honda. the only question is whether they are all universal. maybe someone here can help us out on that.
SSTS
SSTS
this is something that unless ordered online, you will most likely only get at the dealer. especially the electrical conector.
Thanks guys,
I order it from the dealer for $120. . I searched online for few minutes and found it is not possible for anyone to carry this hard-to-sell item.
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
