Seat Heaters periodically work
Old 01-29-2011, 09:33 AM
8th Gear
G8torz2's Avatar
I have an issue with the seat warmers on my TL, in warmer weather(above 38*) everything works fine, but when the temp falls at night,(below 30+) they do not work in the AM. Once it heats up throughout the day, they start working on occasion.This could last for a few days before they work again. I'm thinking relay. I checked wires and fuses. Any suggestions???????
Old 01-29-2011, 12:19 PM
B A N N E D
friesm2000's Avatar
more then likely in the seat heater elements in the seat itself, is where most people seem to have the issues of them not working
Old 01-29-2011, 02:14 PM
totaledTL's Avatar
Checked seat elements wiring? That's usually the problem. Best I rem. you should measure about 5 ohms per element.
Old 01-30-2011, 02:20 PM
8th Gear
G8torz2's Avatar
Thanks for the reply's,I'll looks at those if necessary, the weird thing is what when they don't work, the lights on the switch don't come on, leading me to believe that it's something from the switch on back to the battery. Also, I am not turning on the mirror warmers, since only one can be used at a time.
Old 01-30-2011, 03:08 PM
B A N N E D
friesm2000's Avatar
why is that?, cause they should be able to be turned on at the same time; by the sounds of it, you might have bigger issues
Old 01-30-2011, 11:39 PM
Unregistered Member
Karanx7's Avatar
Wait, we have mirror warmers? Is that a JDM thing or are you talking about something other than the side view mirrors?
Old 01-31-2011, 06:40 AM
totaledTL's Avatar
Yes, you have heated (side) mirrors. Switch is toward the front of driver's armrest near pwr. window controls. Might depend on year model, mine ('02) has them. Indicator light when turned on.
Old 01-31-2011, 07:57 AM
dukelx2005's Avatar
I am having the same problem with my Heated Seats,
I believe they are not working either!!
Old 01-31-2011, 08:58 AM
kzak's Avatar
Seat heaters not working is a common problem.
VIDEO: How to fix Acura TL seat heaters
The heating element burns out easily.
Old 01-31-2011, 01:30 PM
B A N N E D
friesm2000's Avatar
03 is the same
but a better location explanation, is that it is on the power mirror controls, right next to the side select for adjusting what mirror
mada51589
05-03-2022 08:54 PM
acurajj
09-19-2015 03:47 PM
EE4Life
09-11-2015 10:13 PM
04tler
09-10-2015 01:13 PM
Quick Reply: Seat Heaters periodically work
