Leaking Transmission oil?
Hey, I drive a 02 TL-s it's at around 120k miles.
I drove it on the freeway the other day for approx. an hour, and as i was parking and I turned off my engine, I see smoke coming from the front.
At first i thought it was the radiator, but as i checked the color, it wasn't green, it was brown. So i checked the motor oil, and it wasn't it either, and when i checked the tranny fluid, it was low, and still leaking.
the thing is, when my engine is on, it doesn't leak! i checked under my car and i see that it barely leaks when my engine is cold. so i refilled it with the non-honda atf fluid that the manual said was okay (temporary).
I hope it's just a seal that are common of failing on this car. i tried searching with no luck in finding specifics. i read that i had to remove the transmission and replace that 10 dollar seal. I'm willing to do the work and post up some diy.
Click here to go to the part list
Does anyone know which part number, because i don't really see which on is the rear main seal.
ENGINE rear main seal--to see if that really the problem remove the 2 10mm head bolts and the inspection cover at the engine/trans junction under the car
If the fluid is coming from up inside there- its engine or trans seal
check the fluid color, red-brown is trans fluid and it is a front trans seal
blackish is probably engine oil and rear main seal $7
see if thats where the leak really is
There are other places,, like the seal where the driveshafts come out of the trans,,,otherwise you may have a major problem and need to consult the last pages of Tranny Failure thread for advice on `cars over limit` and `goodwill coverage`
kris- so you- who has dismantled and reassembled 2 ore more of these exact trans from your TL,,there is no front trans seal inside the inspection cover area?
only the engine rear main? is that correct--or is it both
I will go under my car and check, I will post up some pictures after trying what 01tl4tl said.
Thank you 01tl4tl, Rajca, and Kris.
I believe the seal in question is #11
mada51589
Jan 9, 2025 04:40 PM
asahrts
Sep 4, 2015 05:55 PM
