Leaking issue on front drivers side pillar
I have a 2002 acura tls and i'm Looking to find the water issue coming down inside of my car on the drivers side front pillar. It starts at the top seam from the roof and runs down the pillar. Does anyone have a way of checking where this is coming from? Or help removing the panel to see where the water is coming in. Any help is appreciated. Thank you.
I had a similiar leak and it turned out to be the top corner of the windshield. I used some windshield sealant under the molding around that area and it stopped the leak. Yours could be the sunroof drain clogged up so check that too
Thank you. I just had my windshield put in so maybe it is that. Thank you
IHaveNoIdea2012
2G CL Problems & Fixes
05-09-2016 04:45 PM
