Keyless Entry problem
Old Nov 7, 2013 | 04:44 PM
swllen_cu's Avatar
Hey guys haven't been on the forums for a while now but ran into a problem that I can't figure out.
My factory keyless entry on my 2001 2G is not functioning anymore and I can't seem to figure it out. The remote lights up perfectly, but it doesn't lock, unlock or open my trunk. I've tried to replace the battery with no luck and I also checked all fuses. I even tried to reprogram the remote and that won't work either.
Any suggestions?
Old Nov 7, 2013 | 05:02 PM
3.2TLc's Avatar
Do ya have a spare ?
Old Nov 12, 2013 | 01:57 PM
swllen_cu's Avatar
no spare.. just one key and one keypad when I bought the car about 3 years ago.
Still haven't been able to figure out the problem... anyone ?
Old Nov 20, 2013 | 11:47 AM
swllen_cu's Avatar
bump.... problem is still lingering.. I've even checked all the power door lock connectors behind the door panel and they are fine.. even unplugged and plugged them back in
Old Nov 20, 2013 | 12:24 PM
buugiewuugie's Avatar
9th Gear
Does your driver's side door power lock work? Does it cycle when you use the lock/unlock switch on the door panel?
Old Nov 20, 2013 | 01:52 PM
nats007's Avatar
I'd try a new remote. I ordered one on eBay (generic aftermarket)since I did not get one when I purchased the car, programmed it with the provided instructions, and it worked fine.
Old Nov 20, 2013 | 04:30 PM
swllen_cu's Avatar
Hm... I may try that, but at a last resort.
yes it works perfectly.
Old Nov 20, 2013 | 05:25 PM
3.2TLc's Avatar
If it bothers ya, try a new remote as Nats007 suggested.
Old Nov 21, 2013 | 11:07 AM
9th Gear
Before you spend money and buy a new remote, have you tried to reprogram your current key fob?
Old Nov 21, 2013 | 05:49 PM
3.2TLc's Avatar
Question keyless entry problem......
Swllen_cu stated that he tried to reprogram the remote. Perhaps there's a special technique to doing this properly ? IDK !!!
Check out some previous threads on the subject.
Old Nov 25, 2013 | 12:35 PM
swllen_cu's Avatar
yes I have tried to reprogram it.. but the remote doesn't even respond to the car at all... I can't even get the power locks to cycle
Old Dec 5, 2013 | 11:36 AM
swllen_cu's Avatar
problem is driving me nuts... I'm about to say fuck it and bring it into Honda/Acura dealership....
Old Dec 5, 2013 | 11:38 AM
swllen_cu's Avatar
http://www.ebay.com/itm/1999-2000-20...a0eb48&vxp=mtr
was thinking about just getting this used remote before bringing it into a dealership.. what are you guys opinions?
Old Dec 5, 2013 | 01:58 PM
jzhu625's Avatar
buy the one from ebay and try to program it to your car. if no luck then Dealer
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
12vancover
Oct 16, 2015 12:04 PM
